My 440 is running a genuine stock Chrysler radiator - 22" wide (3) core - with a stock (6) wide blade fan and stock shroud.
I am entertaining the idea of going with (2) 10" electric fans that will pull 2100 cfm. From what I read, this is enough to handle 800 hp. Not really a fan of electric fans, but if it can be a solution to this possible heat soak, I am experiencing, when idling or slow speeds then Mmmm?
At this point in time the radiator might be another thing altogether. I am considering having it "rodded out" just to verify if it's gunked up or not (good money after bad intentions?).
This morning I hit upon the idea of needing to know what a stock fan will pull - cfm - at an idle. After googling it I found page after page about cfm rating on electric fans, but nada on a typical stock fan. Anyone have any ideas on this? If the electric fans are not enough to add a substantial difference -cfm at an idle - then my next thought would be adding a clutch setup to my stock six blade fan.
Which brings me to this question: Can having a wild, loppy idle cause eventual problems with a clutch fan? I know! Stupid question, but I had to ask.
