Which intake gaskets (from Fel-Pro)... if you choose to have the exhaust cross-over port open (for manifold heat to warm up the carb during cold operating temps)...  then simply use the common MS-90109.   the side rail gaskets are metal cored with fiber facings that have raised embossments around each critical sealing area.  These gaskets also have a blue Teflon anti-stick coating for a supplementary sealing agent that also acts as an anti-stick for easy removal if/whenever needed.  Additionally, this MS-90109 set includes 4-plastic alignment dowels to attach and align the side gaskets into the heads.
IF your intake manifold does not have the center exhaust cross-over port (as many aftermarket aluminum manifolds are)... then you could still use the MS-90109... or else, use the Fel-Pro Performance intake set #1213.   Those side rail gaskets are a dense fiber with Print-O-Seal sealing beads around each port; the dense fiber material is good for conformability as some aluminum manifolds have slight warpage and/or corrosion/pitting.
Regarding the search for the molded rubber f/r end seals, forget it... for small block Mopars... many years ago, I'm pretty sure that all gasket companies have already switched to the cork-rubber seals because of their better compression (up to ~50%)... whereby rubber is not compressible... it distorts upon being squeezed... and will commonly split apart beyond ~30% of squeezed.  As an option, you could simply apply about 1/4" bead of RTV silicone (any kind, but black is suitable as it will resist the common temps at that location).
Finally, when you install the side rail gaskets, regardless of the F/R sealing you choose, be certain to apply a small dab of RTV silicone at that the 4-intersecting points of the manifold/head/ends.
Before installing the manifold, do yourself a favor and tap the head threading for the intake bolts, as well as run a cleaning die over each bolt thread -- you will be glad you did this (general practice for any assembly).
Here's a tip:  On many SB Mopars, there may be front and rear metal dowels -- used to align the end seals as well as the intake manifold.  However, sometimes the height of those dowels will cause the manifold to not come down enough upon being tightened, especially if there has been any resurfacing done to the block/heads or manifold.  So... best if you just pull them out.  Most aftermarket aluminum manifolds do NOT have the small hole F/R for the dowel... so again, best to remove the dowels.
Another tip:  As for the plastic alignment dowels (as included in the MS-90109 set), depending on your manifold, it could be an advantage to grind a small relief area (tear-drop relief shape) into the manifold areas that the plastic dowels will be positioned (common 2nd form each end).  I've seen OE cast iron manifolds with these reliefs, but never have I seen an aluminum (not the Eddy OE or aftermarket six-packs) having these tear-drop shaped reliefs.  The slight raised height of the plastic dowels could, possibly, pending the manifold bolt hole diameter, hold up the manifold from being fully tightened down to the side rail gaskets.   Most people are unaware of this matter when using the plastic alignment dowels with their intake manifold.... same scenario with the F/R metal dowel pins.
Final tip:  On some aftermarket aluminum intake manifolds (regardless of engine brand), the intake ports may be slightly mis-aligned due to casting shift.  The result is that the gasket may not seal properly around the ports... the raised sealing beads (either with a metal-cored gasket or the dense fiber gaskets) could fall uncompressed inside the ports -- not good!  So, you have to visually inspect the alignment of the casting ports with the gasket ports.  A dense fiber gasket can be trimmed to fit more easily than a metal-cored gasket.... but the critical concern is the positioning of the sealing beads on the gasket -- those are what does the sealing... the raised beads.  IF they fall into the ports (due to a bad casting/core shift), then you will have a problem... get another/better manifold will be the solution.
