Rebecca Harvey
- Joined
 - Jan 28, 2020
- Messages
 - 10
- Reaction score
 - 3
After engine upgrade (built 340 with aftermarket water pump and radiator) the lower hose will not fit. It now has a Griffin radiator (2 row) and Milodon water pump. Visually the radiator looks about the same thickness as the original (with some trimming we were even able to fit on the fan shrowd). However upon installation we found that the lower hose was too long and the bottom elbow hit the k-frame. So we started trimming. we shortened the part before that lower elbow so that we were just able to push it on and not have it hit (I think that was about an inch cut off). However, it still was a little too long at the water pump end so we cut it a little there too. The result was that it was now too close to the fan belt. I suppose some people go with an electric fan but we want this to still look a little original - the new engine is dressed to look like the original 340).
Has anyone ever had this problem? Should we try a flex hose? I have never used a flex hose and am skeptical about quality. However, we must have a secure fitting lower hose (we cannot put our new engine at risk). I will post a photo if I find one.
thanks, Rebecca
thanks, Rebecca
