70 challenger 440 manifold gasket
Shut
FL
Hello to all,
I need to change the manifold gaskets and in rockauto there are a lot of, can you help me to choose one please??
Thanks in advance
I would use the Fel Pro 1215 , it will block the heat crossover port which helps as these cars are rarely driven in extreme cold .
I use a single fiber gasket between the intake pan & the heads on each side to keep oil from seeping up into the intake .
Shut
FL
Thank you Psycho!! Mine have heat core and I use it, because here I can use the car in the winter (without raun of course)
can you explain me this please?? I dont know??
Shut
FL
Apologies because I mean manifold to exhaust gasket Psycho. Sorry my poor english
The factory never used gaskets between the manifold & head , if you do use gaskets they will cause leaks , I just usea small amount of copper RTV .
Shut
FL
I upload 2 videos to youtube:
DetMatt1
I know Chrysler did not use gaskets there but I do on mine and I drive them quite often and have never had one leak. I‘m actually not a fan of RA and try not to use them if I can avoid it but I’m not in Spain. What I can’t get at my old school auto parts counters here in the Detroit area I’ll order from Summit, Mancini’s, Roseville etc…
Shut
FL
thank you very much DetMatt1!!!!
