440 clearance under challenger flat hood
A3404bbl
virginia
Good morning everyone,
I have a ‘74 challenger that was a factory 318 car with the flat hood, that I am swapping to a 440 based 512 stroker. My questions are:
1. will the 440 fit under the flat hood with carb and air cleaner?
2. Does the bracing on the underside of the R/T hood allow for extra clearance, or is the buldge in the hood just cosmetic on the exterior?
Thank for your help!
Yes the ralley hood adds clearance , yes the 440 will fit but you may need a drop base air cleaner , the intake used also has a great deal to do with clearance .
The RPM is a taller intake , the Holley Street Dominator would be a better choice as it is only about 3/4" taller than stock , you won't even lose any power with the Street Dom especially if it is ported .
Glas86
This is a 440 with CH4B intake in my challenger with flat hood. It does clear the hood but the aircleaner would touch one of the braces every now and then under heavy acceleration. A dual snorkel air cleaner would give me more clearance so there is no interference.
A3404bbl
virginia
Thanks for the info and pics. Beautiful car! I have a tall deck 440 and a taller intake which is causing my clearance issue. The flat hood will close with no air cleaner or air cleaner stud in the carb. I went ahead and ordered the rallye hood to get the extra clearance I needed.
cv70chall
South Florida
Hello,
I've been searching for that style air cleaner for a while. I've got a 70 Challenger that I upgraded from a flat hood/ 318 to a Rallye Hood/ 440 a while back. Any idea where they can be had?
Glas86
I have a single 4barrel carb so an air grabber air filter worked for me.
You can get them at pg classics.
There is one for 440 and one for 383. The 383 one sits higher. I got mine on a swap meet buts its identical to this one:
