Biggest back tire
jkling1974
scaggsville md
I have 15x8 4.5 bc . On my 74 challenger . I have 275 60 15 on them . They don’t fill the hole like I want . I want like a 275 70 but they don’t make it .
Any ideas ? I want taller more than wider . I’m happy with width of 275 . Just side walls look to small for this car.
jkling1974
scaggsville md
Bug Guy
California
Do they make a truck tire close to a 275 /70/15 ? I want this thing fill the hole .
Hey I have the same problem you have. The tire I want is a BF Goodrich 295 /50 /15, But my problem is they only make that tire in a 15 inch rim size passenger tire , I need a17 inch rim because I have add big rear disc to my car . I don’t want a rubber band tire real low profile , The tire I want is a 295 /45/18 aSUV tire. The wider the tire you want your rim size goes up and your profile goes down 45/40/35/30 , 18-19-20 rim size, I’m looking at Mickey Thomson tires , I want to do some auto cross so I want a High Performance Tire , not all tire manufacturers offer the size and profile I want and the prices are $250 to $ 500 a tire !! I’m going to rethink what I want, Good luck on your project Ray
gzig5
Mequon, WI
Cooper makes a 255/70-15 and I have them on the back of my Cuda on 15x8 wheels. It's supposedly a 29" tire and it definitely fills the wheel well. In my case the offset of the wheel pushes it out to the limit of the fender. No room on the outside but plenty of room to the frame rails. front is a 255/60-15
Cuda Hunter
high mountains Colorado
a few pics.
gzig5
Mequon, WI
Gzig5, those fit really well and look great!
I have Micky Thompson's, 29.5x9.0-15
Thanks. I like the look but it would be nice to have a 275-295 width. I'm currently in process of replacing both full quarters and will be trimming or rolling the fender lips before paint to maximize the available width. I've got a 66 B-body housing and 1" spring relocation brackets which should allow me to get a 305 wide tire on the back. Have a ways to go before I need to decide on the size. I'm hoping I can find something in 17/18" wheel but there is a much better selection in the 19" diameter.
I'd say you've about maxxed out what can fit in that opening.
rklein71
Amarillo Texas
I think it will look better sitting on the ground or at least jack stands under the diff as the wheels hanging down doesn't give you a good look at tire fit.
Bug Guy
California
Here’s a picture of the BF Goodrich 295/50/15 on my Cuda w/15/10/ 6 1/2 backspace this rim has a center that slides in or out to see what size will fit underneath your car. That’s the look I wan but rear discs won’t let me run a 15 inch rim have to go to at least 17 or 18s
Like someone else already said. You have the suspension hanging, put the stands under the axle housing or put the car on the ground. Someone asked about the same non existent size ( 275/70- 15) a few months ago...
The answer is still the same, they don't make a passenger tire in that size. Period. Never will. The only way to get a taller tire that is just as wide is to go with racing tires. or truck tires. same answers.
They come in different sizing, like truck tires. 30" X 10". -15 or similar.
Or you have to narrow the rear, widen the tubs and then you are not limited on height.
Tire sizing is a formula.
It breaks down to 275 ( Section width in mm.) / 60 or 70 or whatever ( Aspect ratio % of tire height to section width) and the the rim diameter. So a 70 series tire is 70 % as tall as it is wide ( section width, not tread) and so on. The lower the series, the lower the tire height.
Or just lower the rear of the car.
Just remember what size tires were available when these cars were new... Talk about not filling up the fender wells.
I have always found the opposite , the 275 is too narrow & 60 makes it too darn tall , I went with a 295 /50 , with the narrowed diff 305-315 width should easily fit especially with a 17" rim
1972 AAR Cuda
Washington state
With the right offset you can get 295's in - maybe a little wider if the offset is perfect...
Here are 295 40/17's on my Barracuda:
I found this to be just about perfect for me - tire diameter vs tire width vs tire sidewall and stuffing the wheel well all in one package.
Bug Guy
California
Here are 295 40/17's on my Barracuda:View attachment 93812
Hey that’s good I’m doing QA1 Rear Suspension set up, I like the size of the tire what’s the brand of tire?
IS this what you were refereeing to? ////
OK, lets get a tire/tyre size combos thread started. Too many wasted threads about one topic.
Chryco if you or Ross or someone could sticky this topic that would be good.
Post what rear end you have, tire size, wheel size + back spacing etc
Also any mods or relocation kits that were needed to fit your wheel combo along with photos, definitely PHOTOS.
I'll go first:
1970 Dodge Challenger R/T
8-3/4 SureGrip
15x8" Rallyes Rear with 275/60 BFGoodrich Radial T/As
15x7" Rallyes Front with 245/60 BFGoodrich Radial T/As
Chrysler Rallye wheels: 56 Series purchased from www.jegs.com All wheels have a 4-1/2" (4.5) Back Spacing.
Rear trim rings leave a 1" gap due to the wheel being 8" and repro/OEM rings only available in 7" sizing.
No rubbing, no relocation kits, no worries.
Cheers,
NZ440R/T
Panther Pinks Combo:
295/50 R -15 with little clearance to the leaf spring. Fits inside the wheel wells though. Re: E-Body Tire Combos
« Reply #2 on: March 31, 2006 - 06:56:30 AM »1972 Dodge Challenger
Centerline Autodrags rims and BFG T/A Radial tires.
The fronts are 15x7's with 3-5/16" bs on 225/60/15's
The rears are 15x8.5's with 4-7/8" bs on 295/50/15's
******NOTE: This is on a stock E body width 8 3/4 rearend, I HAD to use a 7/16" Mr.Gasket wheel spacers to give the tires at least 1/2" clearance from tire bulge to leafspring, because all it had was 1/16" to 3/16" clearance without them. I also installed 3" long ARP wheel studs and open end lug nuts in the back, so I'd have plenty of threads for the spacers*****
***So if you like this look and want to use a 8.5 wide rim just find a rim with a 4 1/2" backspace and you won't need any spacers! Yet it will look the same.
It just barely touches the drivers side when I hit a big bump, but I'm still using stock shocks with re-arched leafsprings. If I added KYB shocks or rolled the inner lip a little or trimmed it wouldn't hit.
I have 275-60-15 MT drag Radials on 8 in ralleys now.. but i had MT 12.5 x 28 Street ETs on the same wheels on it before. Just had to use a half inch spacer Just put on new tires. Car is a 71 cuda--stock 8 3/4 rear with new espo 1" over stock height springs. To fit 275/60-15 tires I had to buy new 15x8 ralleye rims(from wheels vintique) 4.5" backspace. Front tires are 235/60-15 on stock 15x7 ralleyes. Here's my info for the 14" crowd:
1972 Challenger Rallye
Stock suspension, 8 3/4" rear end
Factory Mopar 14"x6" Styled Road wheels (Magnum 500 style)
Fronts: 215/70R-14
Rears: 225/70R-14 (a little taller and wider)
For the 14"x6" rim, from what I saw, the widest tire you can "safely" mount is a 225/70R-14 or a 235/60R-14 tire.
There's also a pic comparing the 2 sizes.
Take the tire size of the new and old to convert to OD diameter of tire. Google a conversion chart to do. Even though wheel size new is larger the tires are low profile. Disc brake size is why new cars use big wheels mainly along with looks. You might get away with the 18 inch new wheel and a low profile tire if off set is close. My 245/45 20inch Goodyears are 28.7 inch dia. Look up your old tire dia. It will be pretty close. 15" wheel with a bunch more side wall. A 205/75 15x7" Tire and wheel will fit 1971 stock Hemi Challenger front end. That tire is 27.1 inch dia, so on my 20 inch at 28.7 dia your about 7/8"x2 differance. Stock 18" Challenger 2009 tire is 235/55 18 at 28.1 dia. Now your at 1/2"x2 dia differance. Look up some lower profile 18 inch. That web site below will provide OEM tire size that far back. Its where I got info. Your turning clearance will be the issue I think if lug pattern is the same along with offset. With 18 inch wheels you can put larger brakes on the front also. Good thing. According to Tire Rack a stock 1970 318 Challenger did come with 14 inch wheels. Good luck.
Now for the rest of the story. ////
/// F70/14 Rim Width6 - 7” Section Width 8.75” Overall Diameter26.45” Rolling Circumference 83.10”
Rev./ Mile 762 Tread Width 6.55” /// 205/60R15
91H SL Tire Weight 22 lbs. Rim Width Range 5.5-7.5" Meas. Rim Width 6" Sect. Width 8.2 Tread Width na Overall Diam.24.7" Revs. Per Mile 842
/// P205/70R15
95T SL
680 A B 1,499 lbs. 44 psi 11.5/32" 22 lbs. 5-7" 6" 8.2" 6.7" 26.3" 790 /// P225/50ZR15
90W SL
40 B A 1,301 lbs. 51 psi 4/32" 20 lbs. 6-8" 7" 9.1" 8.7" 23.6" 881 /// 225/50ZR17
94W SL
340 AA A 1,477 lbs. 51 psi 9.5/32" 26 lbs. 6-8" 7" 9.2" 9" 25.9" 803 /// 225/55ZR17
97W SL
340 AA A 1,609 lbs. 51 psi 9.5/32" 27 lbs. 6-8" 7" 9.2" 8.7" 26.8" 777 /// P255/60R15
102S SL
400 A B 1,885 lbs. 35 psi 11/32" 32 lbs. 7-9" 7.5" 10.2" 9.1" 27.1" 769 /// P225/60R15
95S SL
400 A B 1,521 lbs. 35 psi 11/32" 24 lbs. 6-8" 6.5" 9" 7" 25.6" 813
jkling1974
scaggsville md
Love this but you’re car sits pretty low for me . 255 seem too small maybe I’ll order and put nexy to my 275s
thisbos cool bit I don’t need wider than 275 really . But I want taller than 275/60-15
A little more on tire sizes.
Standard-Metric
Overall Wheel Diameter 78 series 14" Bias Ply 70 series 14" Bias Ply 60 series 14" Bias Ply 78 series 15" Bias Ply 70 series 15" Bias Ply 60 series 15" Bias Ply 75 series 14" Radial 70 series 14" Radial 60 series 14" Radial 75 series 15" Radial 70 series 15" Radial 60 series 15" Radial 50 series 15" Radial
21.8" - - - - - - - - 165/60 R14 - - - -
22.3" - - - - - - - - 175/60 R14 - - - -
22.7" - - - - - - - - 185/60 R14 - - - -
23.0" - - - - - - - - - 135/75 R15 - - -
23.1" - - - - - - - 165/70 R14 - - - - 205/50 R15
23.2" - - - - - - - - 195/60 R14 - - - -
23.6" - - - - - - - 175/70 R14 - 145/75 R15 - - -
23.7" - - - - - - - - 205/60 R14 - - 185/60 R15 -
23.9" - - - - - - - - - - - - 225/50 R15
24.2" A78-14 - - - - - - 185/70 R14 215/60 R14 155/75 R15 - 195/60 R15 -
24.6" - - - - - - - - 225/60 R14 - - - -
24.7" B78-14 - - - - - - 195/70 R14 - 165/75 R15 - 205/60 R15 -
24.8" - - E60-14 A78-15 - - - - - - - - -
24.9" - - - - - - 185/75 R14 - - - - - -
25.1" - - - - - - - - 235/60 R14 - - - -
25.2" C78-14 - - - - - - - - - 185/70 R15 215/60 R15 -
25.3" - - F60-14 - - - - 205/70 R14 - - - - -
25.4" - - - B78-15 - - - - - - - - -
25.5" D78-14 - - - - E60-15 195/75 R14 - - - - - -
25.6" - - - - - - - - - - - 225/60 R15 -
25.7" - - - - - - - - - - 195/70 R15 - -
25.8" - E70-14 G60-14 C78-15 - - - - - - - - -
25.9" - - - - - F60-15 - 215/70 R14 - 185/75 R15 - - -
26.0" E78-14 - - - - - - - - - - - -
26.1" - - - - - - 205/75 R14 - - - - 235/60 R15 -
26.2" - F70-14 - D78-15 - - - - - - - - -
26.3" - - - - - - - - - - 205/70 R15 - -
26.4" - - H60-14 - E70-15 G60-15 - 225/70 R14 - - - - -
26.5" F78-14 - - - - - - - - 195/75 R15 - - -
26.6" - - - E78-15 - - - - - - - 245/60 R15 -
26.7" - - - - - - 215/75 R14 - - - - - -
26.8" - F70-14 - - - - - - - - - - -
26.9" - - - - F70-15 - - - - - 215/70 R15 - -
27.0" - - - - - - - 235/70 R14 - - - 255/60 R15 -
27.1" G78-14 - - - - H60-15 - - - 205/75 R15 - - -
27.2" - - - F78-15 - - - - - - - - -
27.3" - - - - - - 225/75 R14 - - - - - -
27.4" - - - - - J60-15 - - - - 225/70 R15 - -
27.5" - H70-14 - - G70-15 - - - - - - - -
27.7" - - - G78-15 - - - - - 215/75 R15 - - -
27.8" H78-14 - - - - - - - - - - - -
27.9" - - - - - L60-15 235/75 R14 - - - - - -
28.0" - - - - - - - - - - 235/70 R15 275/60 R15 -
28.1" - - - - H70-15 - - - - - - - -
28.2" J78-14 - - - - - - - - - - - -
28.3" - - - - - - - - - 225/75 R15 - - -
28.4" - - - H78-15 J70-15 - - - - - - - -
28.7" - - - J78-15 - - - - - - - - -
28.9" - - - - L70-15 - - - - 235/75 R15 - - -
29.1" - - - - - - - - - - 255/70 R15 - -
29.3" - - - L78-15 - - - - - - - - -
6PKRTSE
I have 315/60/15 Drag Radials on my Challenger. They are 30" tall and fill the wheel well on dia and width.
