Wires running straight to the ammeter around the fuse box/bulkhead connector? You are describing a bulkhead charging system by-pass, by far the weakest link in the original design was routing the charging current through un-sealed, under current rated, Packard terminals. As mentioned, also referred to the fleet by-pass as the factory did this same by-pass on their fleet production (Taxis & Police) with larger alternators. Nothing wrong with this by-pass, do it on all my builds.
If the ammeter and insulators are in good shape and with proper connections, with the bulkhead bypass in place, no need for the engine compartment charge by-pass being suggested here. Especially running stock sized alternator and loads.
The headlamp switch is feed from two deferent places, B1 (headlamps) is spliced to Splice 1 as is the black lead to the ammeter, as are all other factory loads. B2 is fused at the fuse box and powers the running lights and dash illumination.
If you are wanting to reduce the load at the headlamp switch add the head light relays suggested above. However, connect the power feed to the headlight relays to the alternator stud, not the starter relay as pictured if running the ammeter correctly wired. No added loads at the battery/starter relay if running an ammeter. All loads need to be on the alternator side of the ammeter.
What relay is getting hot? Starter relay? What exactly is the issue you are trying to address
Ok ,so running the wire from the red pos side to the relay is wrong to run it from the Alt stud? 1) please confirm this is ok
I noticed the battery pos & starter relay was getting warm when i had the dash gauges out and put the ammeter wires together for test and run purposes to move the car around.
I thought that is how to by-pass the gauge. put red & black together "both hots"
Since putting the gauges & ammeter back in, they seem not to be getting warm now.
I did run the headlight switch Wire to the red side of the ammeter. your saying no good? to run it to the black Alt "load side"? I will try to explain. here we go!
When i bought the car the by-pass outside the fuse box was already done.
They had a Red pos wire running from the starter relay straight to the red side of the ammeter gauge and is still like this. please confirm this is ok?
A black wire comes from ALT stud "load side" to that soldered block in the Harness above the steering column and the black side of ammeter is this a factory soldered taped connection?
It also looks like it runs and connects to a red wire that runs to the fuse box acc & batt terminals and it looks like it runs to the ignition switch?
So it looks like i might need to move the head light switch wire to the load black side of the ammeter gauge and to run the relay to the Alt stud instead of the pos side of the battery?
Honestly i thought they were all hots and could be put together.
Starting to understand how it works from what your telling me.
So again, the red side of ammeter gauge should be ran Alone straight from battery and the load side is the black side which goes to head light switch and fuse box accessories?
