Can you put a shaker and 4 bbl on a 1971 LA 318?
Wisconsin
if anyone could help by telling me wether or not this combo is possible that would be much appreciated.
1972 AAR Cuda
Washington state
Yes - It can be done. The 70 (and 71 I believe) shaker came on the 340 cuda with a four barrel. I believe you can get everything you need to add a shaker from places like YearOne. It would take a four barrel base plate - not all shakers where hemi's and six-packs...
I have been looking at doing this for a while, but it's not cheap.
Wisconsin
Yeah Thanks. I have a 71 with a 318 and I have always wanted a shaker and a 4 barrel fuel injected carb. I was just wondering if anyone had attempted it. Thanks again
Wisconsin
I also dont think there ever was a 318 'cuda but I have cuda door cards and more parts like that so I might make it a 318 'cuda.
pschlosser
Santa Rosa, California
The key thing I see to vary on shaker setups between engine and carburetor combos seems to be the shaker base plate. And they make those after-market for several different setups, some of which are not factory.
A lot of money for just looks. More money would need to be spent on the 318 conversion to a four barrel ( Injection??) Linkage conversion, intake manifold, carb, fuel lines, etc. Just to bolt it on. To take advantage of the four barrel, cam kit, valve job ( install unleaded valve seats on 71 heads) headers... Might as well rebuild the engine OR just put a post 72 360 long block in it.
Anything can be done for a price...
Mid 80s had a Caravelle Police pkg with a 318 4 bbl if you want a correctly sized intake otherwise you would have to use a 340 intake & the intake ports will be larger in the intake than in the head . Otherwise it is possible as there were factory 340 shakers in 71 .
Tommy the Chryco probably has all the needed parts .
6PKRTSE
With a little work or in some cases alot of work. You can make the shaker fit for sure. I have alot of hours in my custom Shaker that I made to clear my tunnel ram and two 1050 Dominator carbs.
Dfr3604cuda
Finleyville, PA
If that’s what you want, do it.
Don’t listen to the guys that don’t wanna spend ANY money.
A cuda with a shaker scoop is very cool.
Steve340
New Zealand
To fit the shaker you need a low rise manifold that has the carburettor pad position the same place as stock.
I have an Edelbrock Performer and all is good.
A single plane or a high rise dual plane I doubt it would fit. The shaker base plate has around a 2 inch offset "sideways" as well.
You cannot go UP much before the shaker hits the hood when you give it some loud pedal.
Mopar426power
Ohio
Technically, I don't think there were any 318 'Cudas made. There were 3 models available in 1971:
Barracuda (BH23 hardtop, BH27 convertible)
Gran Coupe (BP23 hardtop)
'Cuda (BS23 Hardtop, BS27 convertible)
The BS 'Cuda came standard with a 383, but also available were: 340, 440+6, and 426 Hemi.
The Hemicuda came standard with the N96 Shaker hood, for the other motor options the Shaker hood was optional.
I am not sure if the N96 shaker hood was available on Barracuda, Gran Coupe models? Maybe someone knows?
That being said, if you want to put a shaker hood on a 318 Barracuda, go for it! It is your car, make it the way you want!
6PKRTSE
I agree. I love the Shaker on all E Bodies. Built mine my way.
Cuda Hunter
high mountains Colorado
In the years that shakers were available, 70 and 71, there were no BS Cuda's available with a G code 318.
In the years without shakers, 2-4, there were BS 318 cuda's.
I think a shaker on your 318 would be awesome. Do it up. Let's see it!!
