Mikes72
- Joined
- Jun 22, 2020
- Messages
- 42
- Reaction score
- 10
As you can see in the pic below my floor dimmer switch connector has seen better days. I’ve search the web for a replacement with no luck. Are these available anywhere? I can find a pigtail connector but it doesn’t have the plastic base plate. Is that base plate necessary? I can see the advantage of the plate to keep the connector from coming loose but I’m not sure mine will get a ton of use. It almost seems over-engineered.
Thanks!
Thanks!
