I will keep updating this thread just in case it helps someone else down the road. Before I go further I want to back track a little bit to when I installed these brakes lines. As I mentioned I had done this before. In the past I always had to tweak the lines a little bit and most of the lines in this kit were like that. In this kit I had a lot of trouble with the very small line which goes from one valve to the other. You can see it in Image "B". It took me a long time to get that to fit in both places. The other thing was when I installed the one piece front to rear brake line I started at the rear. When I got to the front the line was pointing at the ground (six o'clock) when it should have been pointing at 3 o'clock. This line didn't need just to be tweaked. It was way off. This gave me a bad feeling about these lines and my gut proved to be right. Never in the past had I had a brake line so far off.
Anyway, back to the present. In Line Tube customer support got back to me very quickly. I cannot say a bad word about their CS. The rep pointed me to a video on their website called "How to seat brake lines". First they tell you to inspect the "witness ring". Then they tell you to use a deep socket to make sure the line is straight and to make sure the line doean't move when installed in the valve and you slide the nut away from it. Step #3) is to tighten the nut with your fingers, then using a line wrench tighten the nut snug, then go a 1/2 turn further to seat the flare. Then loosen the nut and repeat this process 3 more times. Then, and I quote, "Each time you tighten with the wrench add a half turn more."
So what I decided to do is to follow the directions given to me by the In Line Tube rep. I only decided this because I already have everything and if by some miracle it stops leaking I can finally drive my car after 4 years of hell with 2 engine failures. This brake problem, and finishing more of the interior are the only things stopping me from finally using the car to attend shows and pleasure driving. So what I did was first I inspected all the witness rings. They all looked good to me. None one of them looked bad like the one in the video. Second I checked the lines that I could with the deep socket and all seemed straight to me but remember that little brake line mentioned above? There is no way to check that one. The deep socket won't fit on it and that is the one that looked like it was bent a little and it is one of the lines that was leaking. It is very difficult to see while on the car if the line moved when you moved the nut away from it like they show in the video. So I moved on to step 3. The first problem I had with Step 3 is that the guy makes it look so easy as he does it on a work bench. It's a lot harder on the car with an engine installed. So I took the proportioning valves out of the car and did what I could on the work bench. I tightened the nuts by hand and then snugged them up with a line wrench just like they say. [Challneger RTA: I do have Craftsman line wrenches which I got 30 years ago from Sears--thanks for your suggestion] Then I tried to go a 1/2 turn further. Most of the time I got close to a 1/2 turn but sometimes I didn't make it that far. The nut was getting really really tight. I did this 4 times and on most of them the nut got even tighter on the 3rd try (IN other words it got really tight well before a 1/2 turn). I hope this means that the flare was getting seated. The other problem I had was there WAS NO WAY I could add a half turn. Most of the time I could barely get the 1/2 turn in after snugging it up. It was getting really really tight and I just wasn't strong enough to go another half turn. I was also getting that feeling that something was going to break if I kept going further. So, bottom line is I tried to follow the manufacturers instructions the best I could. Hopefully someone can help me bleed the brakes today. I will back car the car out of the garage and clean up the mess. I will inspect the garage tomorrow morning to see if it still leaks (I hate to be negative but I fear this will be case). If it doesn't work I will follow MoparLeo's advice and I will immediately order new steel lines from SS Tubes.
