don selleck
Been working on a 70 340 cuda project for about a year had the non original 340 block in boxes with new edelbrock head air gap intake new pistons, Got a friend of mine that been assembling mopar engines for 30 plus years assemble the engine. had a few questionable areas with freeze plugs hole etc with the block. got it broke in and racked up 1250 miles on it using zinc add oil and 80lbs of oil pressure at cold idle, had a very slight antifreeze leak into exhaust would come out of exhaust very slightly on start up the disappear. Then wiped out wiped out the comp cam lifter on #1 or #3, or both havent disassembled it yet. kinda gun shy of messing with this again, so considering a 360 crate long block from blue print stroked to a 408 for more power any one installed one in a 70? and what issues i assume a oil pan swap would be in store and if I'm thinking correct should be same motor mount. thanks in advance.
