7DCUDA383A
Does it matter for a 383 auto what size air filter to use , I See some are 3 in and up to 6.
Was just wondering if I go let's say 5in tall would the carb need to be adjusted.What you show in your picture is adequate for a 383. I've been running similar on my 70 Challenger 383 with no issues.
NoWas just wondering if I go let's say 5in tall would the carb need to be adjusted.
Thanks Rick
In the Engine Masters test, the clear winner was the "salad bowl" with a 14" K and N "Extreme" filter top on it (similar to the above). Adding velocity stacks also had good results.Believe it or not the worst filter on the market are this style. They make you believe that they filter more air from the top and bottom. However, with air coming in from both directions it causes turbulence within the air cleaner and the air does not ram down the carb as one would think. They actually loose several horsepower. We dyno hundreds of engines every year and do all kinds of R&D testing.
I think it was, if I'm thinking of the same test they used a generic BBC, around 500 H/P (maybe it was more?) and then listed each filter as good for up to XXX H/P based on metered airflow. The K and N supported a much higher airflow but wasn't the best.If I remember right, the paper air cleaner filter only cost you like 2 or 3 horsepower, when it's open like the photo in the original post, over the K&N setup.
