WTB 340 Motor mounts wanted
tonysrt
When Chrysler went to the spool mounts on the A body, did they do anything to improve the E body mounts to prevent them from separating. I have a 71 Cuda that had a 383 in it and it was the 2 piece motor mount. I put a Gen2 Hemi and changed K member for the Hemi mounts.
have some if you havent found any can post pics
Hey thanks I,m Interrested
So is it only the left side that’s 340 specific or both sides
How much ?
Mike
Also I,m having a problem with Caliper mounts or brackets
Car was drum and I converted it to Wilwood set up I recently scrapped that during my new Rebuild,got rid of the drum spindles bought a set of Rotor spindles and brackets off a guy from a 70 Barracuda and installed I buy quite a few parts from Dodge boy in WI on Ebay and bought bolts for the mounts however they don’t get all the way flush in the hole so are there also 2 different bolts for the mounts
Only the Left mount is different on the 340 / 360
Dr Diff or Scarebird for brake caliper mounts .
Some aftermarket mounts are available from Mancini or Roseville , they have interlocking poly mounts available for the E body , the sppol mount was a big improvement but E body never got them .
Well in any case how much would you like for the Motor mount I have the right side but will buy the set if not too high
1971 Gran Coupe
How much ?
Mike
Here is a picture of the difference of the two.
How much ?
Mike
Would like to know how much please
