A few 340 questions
billbob1936
Kansas City
Hello. I have a 340 question as to the determination of a factory pop-up engine (pistons above deck). Is the engine block (crank area) casting slightly differently on the early vs. late 340 engines, or is it the original crankshaft stroke itself that makes it a popup engine, or perhaps a combination of the rods and pistons? Also, could my 73 engine be changed with a different crankshaft to make it internally balanced instead of its current external setup, or is that not possible? thanks
Not certain what you mean by a popup engine but the crankshaft rods and pistons are the heart of it. The block casting varies a bit for applications I’m sure, but the cast versus forged crank goes with the internal versus external balancing.
Get yourself a good set of forged internals, stuff them into your 340 block, balance it the way you want and hang on. 😊
Pop ups were for positive deck motors upto 71 I think. After that they were in the hole to cut compression and made to run at about 8.5 to one compression. Mancini had a damn good rotating assembly a while back as a kit. Callies crank, H beam rods and Diamond pistons with bearings and rings. Put one in mine after having it all balanced. World of difference with a good cam. Hughes .576 .593 I think and 4" stroke and 500 on motor. 444ft lbs at the tire.
Is it possible to take a 1970 crankshaft and put it into a 1973 block?
The difference in the 68-71 pistons and the later 72-73 pistons is in the pin to crown height of the pistons. The early pistons have higher crowns and only 2 valve reliefs, where the later pistons have lower crowns and 4 valve reliefs. The rods were the same. I have taken a 340 forged crank and pistons and installed them into a 340 block that came with a cast crank. That was in 1977 when all of that junk was fairly new and not worn slap out....lol. I was a broke kid with little money, and didn't have it balanced, and it was fine because it was all factory parts except rings and bearings. It worked just fine. Now? I would have it balanced because of the need to use aftermarket rods and pistons.
Great information here folks, thanks. I'm trying to wrap my head around the reason Chrysler made the cast version externally balanced, why not keep it the same? I get the understanding that casting is a cheaper way to do it, but why trade internally balanced to externally balanced, resulting in a bigger chunk of rotating steel on the HB, not to mention the weights added to the torque converter. Would it have anything to do with the ease of milling a forged crank to get it balanced versus not being able to do that on a cast crank?
68 - 71 340s used forged crankshafts and 10.5:1 compression pistons. 72 - 73 340s used cast crankshafts and 8.5:1 pistons. To realistically use the 68 - 71 pistons and pump gasoline, you need either aluminum heads or iron heads with a gasket that will deliver around 9.5:1 compression. As to why Chrysler ever went to cast crankshafts instead of forged, it was a bean counter (money saved) move.
I have three 340s now collecting dust! The one built up the most has 10.5:1 pistons and a forged crankshafts along with adjustable rocker arms. Anything less is just wasting horse power.
I'm working towards a build that would be as close to original for the 1970 engine. Would anyone know of the manufacturer for those high crown pistons?
This is what I have so far:
Eagle forged crank #EAG434033106123 3.3100" Stroke, Internal Balanced $999
Melling camshaft #SPD-22 .429/.444 lift, 44 deg overlap and 114 centerline. $217
Edelbrock heads for a 340 pop-up engine #60179 65cc chamber $937 each
Here is an excellent video of a shop performing an engine balance. I guess this would take the homeowner garage mechanic out of the equation. Lol
I ran 93 octane Amoco Super Unleaded gas in my 340 that was all stock in my 70 A66 Challenger back in the day. If 93 ran fine in it then, it will do the same now. I have a 360 in my 71 Challenger conv that has iron J heads and KB 107 pistons. It has 10.7 compression with the gaskets and chamber CC's figured in, and it runs fine on 93 octane. No more than I drive it, I pony up for the ethanol free 93 gas. If you're using aluminum heads, you won't have any worries about too much compression.
Does head gasket thickness give up much in the way of compression? Would a thinner gasket be less reliable versus a thicker gasket, or does brand/cost quality cancel out that issue?
Head gasket thickness certainly can affect the compression ratio. The thicker the gasket, the less compression distance you have. Cometic makes very good head gaskets in many thicknesses, so you should be able to find one that's suitable for your build. Work with your machinist too see what you truly need in the head gasket dept. You will also need to ask him to check you end to end deck height, to see if your block needs to be square decked.
I'm looking to stay with a stock 340 intake manifold for my 1970 build, but see many different casting numbers for the full 6 year run. I would assume that the earlier castings would be of a higher performance? The earlier manifolds have 4 rounds holes versus the later manifolds having 2 oblong holes. What could be the difference here?
Here are a few casting numbers that I've run across:
3462848 (round holes) possibly 68/69/70
3612100 (long notches) possibly 1971
3671918 (long notches) possibly 1972
If sticking with a stock manifold, I'd run one of the spreadbore designs like the 3671918 and put a nice rebuilt Thermoquad on there! Honestly, I doubt you give up more than a dozen horsepower over say a nice aluminum intake (LD340, Edelbrock Air Gap, etc.). But there is a weight penalty of course. Any of the stick 340 intakes is really a great manifold. The 340 was always a high performance engine even when forced to have low compression.
