The broadcast sheet on my '71 Hemi Challenger also has the " Special Handling Car " on it. Does anyone have more specific info on what that really means?Exactly right. As another example my brother's Challenger R/T has SPECIAL HANDLING CAR printed on the build sheet but only one fender tag with the codes on it, no extra SPECIAL HANDLING CAR tag.
Thanks for the prompt reply. Could that occur if the vehicle was to have different option(s) added / substituted in lieu of what was on the build sheetAs others have said, Special Handling refers to the execution of assembly, not to the suspension, per se. When a vehicle requires a deviation in the normal flow through the assembly line, it was handled in a special way. This may be something added extra to the vehicle build, or something altered after it was completed on the line. It may include removing the vehicle from the assembly line for the special order item/request to be executed. It refers to any number of possible changes.
or fender tags ?
I don't think so. Let me clarify: Any option or change that could be documented on the build sheet, will be on the build sheet, and possibly executed on the assembly line without special handling.
The fender tag purportedly contains mostly the data/options the assembly workers needed to know about while the frame and body parts were being assembled and prior to paint. For example, they would need to know if the car had a 22-inch radiator, versus a 26-incher, because the sheet metal was different in the front of the car for the two sizes. Another example might be the type of hood, plain-Jane, rally or shaker. In 1971, this would include the type of fender, with or without gills.
The Special Handling body code plate gave the assembly line worker a heads up they will need to refer to another document to better understand the details. I presume the document would be the broadcast sheet, and here's why:
The broadcast sheet accompanies the vehicle through the assembly line. It has a Remarks section at the bottom. This is were some or all of the special handling instructions could fall. But I cannot say I've ever seen a special handling broadcast sheet, so this is a guess. Reviewing the broadcast sheet of a special handling car would resolve this, because if the remarks section is blank, then we'd know there had to be other documents.
The assembly line was streamlined as much as possible. It would be imprudent for a worker to have to stop, or leave the assembly line, to answer his questions about the special handling. If there were other documents, it seems likely they would have been found alongside the broadcast sheet within the car. And I've never heard about a document other than the broadcast sheet. For quality control purposes, they would want to keep all these together during the assembly process for as long as possible.
The reason I ask is I have a 71 Hemi Challenger w/ a T/A hood and the correct air cleaner assembly. That is; a T/A base plate and lid punched for 2 Carter 4 bbls instead of 3 x 2 bbl Holleys. The fender tags indicates a sport hood ( J54 ). The car was built in April of '71. Since it was late in the model year, supposedly, the factory would install a T/A hood if the car in question was ordered w/ a Shaker and they were out of Shakers at that moment.
Conversely, could the opposite be true; that the assembly line was out of sport hoods at the time the a car ordered w/ a sport hood came by and a T/A
hood was used on the car?
This is just an opinion:
My instinct is "no."
That is too great a change, and too much a manufacturing cost, to be a simple and/or temporary substitution.
But I'm just guessing. How could I know? It's just an opinion.
Conversely, could the opposite be true; that the assembly line was out of sport hoods at the time a car ordered w/ a sport hood came by and a T/A
The pics of the T/A Hemi aircleaner as well as the broadcast sheet (PDF attachment) are posted earlier in the responseSpecial handling cars are documented on B and C body cars as stated above.
If it were on an E body we need to see some documentation. Would love to see an E or an A with special handling tag. And a broadcast sheet that has special handling on the bottom print.
Does your car have a broadcast sheet?
Can you post the fender tag?
Is this your TX9 black JS challenger then?
And the parts on the car?
Any date codes on the parts in question?
Thanks for pointing that out as I did not see the attachment.Please see the comment on the bottom of the build sheet.
the broadcast sheet posted above belongs to the car.
