Hey all, I'm installing my trans and having a slight issue. As I jack up the trans into the tunnel it pushes slightly to the pass side and starts to hit the brace. Does anyone have any suggestions on how to fix? Running RMS front K member 1" forward mounts. Using holley trans crossmember and 8HP90 adapter plate. Everything fits great except this issue. You can see in the photos that when lowered it is somewhat centered. Then when I jack it up it starts shifting to the pass side.
If anyone has some suggestions I'm willing to try. I knew everything was going to smooth to be true.
