71 Challenger Assembly starts
MOPAR turn signal Switch colors---------- After market Switch colors-------------AAW wire colors
Stop lamps-------------White -----------------White------------------------------------White
L F turn signal --------LT Green--------------GREEN ----------------------------------Light blue
R F turn signal -------Tan---------------------Orange/Blk Stripe ------------------Dark Blue
Emg Flasher ----------Pink-------------------RED --------------------------------------Brown
Turn signal Flasher--Red---------------------BLUE ------------------------------------Purple
L R turn signal-------Dark Green----------- Lt Blue--------------------------------Yellow
R R turn signal-------Brown-----------------Yellow -----------------------------------Dark Green
Horn relay------------Black-------------------Grn-w-----------------------------------Black
AAW wiring. So you needed to cut the plug from the switch? This is what the colors would be on a new turn signal switch. The AAW wiring colors. Figure F. The Mopar wiring colors. My opinion: If you have the the car side of the turn signal sw plug. I would cut it with enough wire to remove the insulation. Then soldier the AAW wires to the plug wires and have shrink tube on before soldiering. Or get one. That way you retain ease of replacement and or trouble shooting. They are low current.
BEAWARE After market switch colors may vary. Pay no attention to the color chart in the picture. I have no idea what it is referring to.
R F turn signal -------Tan---------------------Yellow/ Blk Stripe ------------------Dark Blue
L R turn signal-------Dark Green----------- Lt Green --------------------------------Yellow
Horn relay------------Black-------------------Grn/w-----------------------------------Black
AAW wiring. So you needed to cut the plug from the switch? This is what the colors would be on a new turn signal switch. The AAW wiring colors. Figure E. The Mopar wiring colors. My opinion: If you have the the car side of the turn signal sw plug. I would cut it with enough wire to remove the insulation. Then soldier the AAW wires to the plug wires and have shrink tube on before soldiering. Or get one. That way you retain ease of replacement and or trouble shooting. They are low current.
Thanks much - and yes I have had my soldering iron flowing throughout the total rewire.
THanks so much.....
Ok so I wired it like above and my right and lefts were crossed up. Flashers were fine. So here is the final arrangement which I will share with AAW peeps as they did get back to me:
Aftermarket Switch PigtailAAW Colors
Stop LampsWhiteWhite
LF Turn SignalGreenDark Blue
RF TurnsignalYellow/Blk StripeLight Blue
Emg FlasherRedBrown
Turn Signal FlasherBluePurple
LR Turn SignalLt GreenDark Green
RR Turn SignalYellowYellow
I will solder everything this weekend, heat shrink it, and move on to ignition wiring!
Also note the SPEEDO....when I connected the cable and drove it - it did not move....????
Man that car is coming along! Absolutely beautiful
Thanks - when I pulled the title to get it registered this week I see I bought in 12/18....over 7 years, one defaulted body shop, hours of research, and help from all of you and here we are!
At last after 7 years here we are.....the 340 4bbl is an absolute rever....with 4:11 gears....not sure I will keep them but until I break in the motor we will leave it. No rattles. No noises....one last bug - wipers won't park....I have all summer to figure it out. Thanks to all who helped me along in the project with advice, pointers and tips and tricks....time to burn rubber and go get ice cream.....over and out.
Looking for some wiring help. Trying to wire into my American Autowire connector. The AA diagram looks like it has the old colors for a stock turnkey switch. Aftermarket Turnsignal has the following colors on the connector:
WHITE (At the pointed End)
GREEN
MUSTARD/Blk Stripe
RED
BLUE
Lt Green
Yellow
Green/White Stripe
I cannot find a pin out anywhere for these colors....anyone got one?
