Need to replace Steering Gear Box in my 70 Cuda
WhiteGP
Looking at the Lars 11033 which seems to be a stock unit, has anyone installed a fast ratio gear box such as the Lars 11043, and if so any comments on going that route ?
WhiteGP
Thanks everyone ! Bergman / Borgeson it is ... Since my pump is leaking also, the complete kit seems to be the way to go !
the website says it should be a small sector, ( see below ) I talked to Pete Bergman, he said small sector
market that bolts in directly, uses factory parts and does NOT require cutting your steering column!
Small sector boxes were used on 72 and prior vehicles, except C bodies.
NOTE *Due to the higher operating pressures of the updated style steering box, a cooler is recommended*
WhiteGP
[/URL][/URL]
The Bergman Auto Craft kit is a Borgeson PS unit and is 14:1 ratio.
You must know if you have the small or large sector before ordering.
Bergman mentions ( recommends ) the cooler for the PS unit ? Did you add a cooler ?
Sal C
Chicago
Borgeson, best upgrade. Half the size and weight, installation was a breeze...
Katfish
Palm Bay, FL
Lars unit looks interesting, basically same as Borgenson.
It looks like you have to buy some extra parts separately though?
I have the Borg box, not as impressed with it as others here.
don selleck
michigan usa
I have an original one that needs restored, just clean up and paint, was planning on using it, but after the last post its got me thinking that would work alot better especially in front of the radiator
michael bucklew
got to replace steering box on my '71 challenger small block, power steering. which part number, for Borgeson?? also cooler is recommended, how was installation, any pictures and hose routing would be helpful. Michael 71 challenger
WhiteGP
Hi Michael
I ordered the master upgrade kit from Bergman Auto Craft since I need a pump also,... have not got it yet, Home - Bergman Auto Craft - Home of Quality Muscle Car Parts Shoot them an email or call, they will know which box to send I believe, the also have pics and instructions for the install
Hope this helps....
Raycuda
Florida
Thanks RayCuda, got the Borgeson Box, Pump and cooler installed, I'm thrilled with it !!!
I am so happy you are thrilled with your install. As I said, my brother did it and he loves it. I drove his car, and the feel is fantastic, nice and tight, not sloppy like mine feels. Time to bite the bullet and do mine next.
