X2The Bergman Auto Craft kit is a Borgeson PS unit and is 14:1 ratio.
You must know if you have the small or large sector before ordering.
Thanks everyone ! Bergman / Borgeson it is ... Since my pump is leaking also, the complete kit seems to be the way to go !
[/URL][/URL]
the website says it should be a small sector, ( see below ) I talked to Pete Bergman, he said small sector
market that bolts in directly, uses factory parts and does NOT require cutting your steering column!
Small sector boxes were used on 72 and prior vehicles, except C bodies.
NOTE *Due to the higher operating pressures of the updated style steering box, a cooler is recommended
Bergman mentions ( recommends ) the cooler for the PS unit ? Did you add a cooler ?The Bergman Auto Craft kit is a Borgeson PS unit and is 14:1 ratio.
The Borgeson unit is the way to go. My brother installed it in his 340 car, and it works beautifully.The Bergman Auto Craft kit is a Borgeson PS unit and is 14:1 ratio.
Yes, this one from Hayden. Full kit.Bergman mentions ( recommends ) the cooler for the PS unit ? Did you add a cooler ?
Let me know if you wanna sell it.I have an original one that needs restored, just clean up and paint
Hi Michaelgot to replace steering box on my '71 challenger small block, power steering. which part number, for Borgeson?? also cooler is recommended, how was installation, any pictures and hose routing would be helpful. Michael 71 challenger
will do. pump is ok. trhanksHi Michael
I ordered the master upgrade kit from Bergman Auto Craft since I need a pump also,... have not got it yet, Home - Bergman Auto Craft - Home of Quality Muscle Car Parts Shoot them an email or call, they will know which box to send I believe, the also have pics and instructions for the install
Hope this helps....
