What carb size mopar 340.
rasmus westlin
Recently bought a -71 challenger with a 340.
Specs are
340” drilled 0.30
Eagle rods
Keith black pistons
Edelbrock torker 340 intake
Edelbrock rpm heads that are matchported.
Xtreme Energy 236/242 Hydraulic Roller Cam (COMPS CAM) grind number xr286hr-10
Mopar performance distributor with plugged vacum. 18 advanced timing with 34 total.
The carb on right now is a holley street avenger 670 with vacum secondary.
its also a 4-speed car with 3.55 gear in the rear.
I cant get the car to run nice on light throttle, it just bogs and hops when trying to run in ordinary trafic. I have read alot of people having problem with this carb. Should i take it of and buy a quick brawler 650 or 750 DP? (Holley made). The problem is on the primary side and i read that you need to drill or change the metering block to get it to work good.
Hope i can get some good tips and help! Thanks.
Hi, Did you do the engine work or was it already done when you bought it ?
If so has it ever run properly ?
Or have you replaced anything since you got it and now it has a drivability problem?
Street car, reconnect the vacuum advance.
That is a race track move.
Too much initial timing. What counts is not how much total timing you get but how fast you get it.
Initial closer to 12-14 ° Should idle less than 900 rpm. Check vacuum at idle as well. as close to 19 lbs as possible. No double pump unless you like to burn a of of gas. Another track item.
Steve340
New Zealand
Can you borrow a known good carb of a friend to try it ?
If the problem is gone you will eliminate the engine, ignition etc.
If you do replace the carb my advice is if mainly street driven go vacuum secondary.
rasmus westlin
I gonna try and see if i can borrow from a friend and see. Why is it better to have a vacuum secondary? I feel the car has a quite performance built engine, even if its for street. The carburator that is on now seems like it would be better on a more original built engine with less cam and so..
pschlosser
Santa Rosa, California
Mechanical secondaries are more sensitive to timing, and linkage changes, and can open too fast for the engine, causing a slowness in acceleration. Better suited for the strip than the street, but once dialed in, they perform quite well.
Vacuum secondaries open slightly slower (milliseconds) than mechanical ones. But they are driven, more or less, by the demand of the engine. These are easier to adjust to ideal opening speed.
pschlosser
The original carburetor for the 1970 (for example) 340 was rated for less than 400CFM. You're gonna have to take your engine over 7000 RPM before you outgrow the 670 CFM you have, now. BTW, your 670 is a 4150 clone, a really nice carburetor that many enjoy using on their mopars, even 440 engines.
We don't know how broken or modified your current carburetor is, so borrowing another for testing has some really good value.
I think ANY carburetor you buy new, will need some adjusting and possibly a change to the jetting to be ideal. So new or used, you may still be looking at troubleshooting and adjustment. Any way you see it, you're looking at figuring out the problems.
In the past, when I wanted a simple "bolt-on solution" with minimal adjusting or tinkering, I've always reverted back to factory OEM hardware. But those parts are getting harder and harder to fine in "working order."
While you don't have to use something new, I recommend using something that is already working on another engine as your primary goal.
If you don't have the time or motivation to figure this out, then you have to pay a shop to do it for you.
gzig5
Mequon, WI
Modifying the carb to work the way you need it shouldn't be too hard, and it's a lot cheaper than a new one. If going with a new carb, I'd put on an AVS2 650 or maybe even the 800cfm if you are going to wind it out. I put a 650 AVS2 on my Cuda's 340 and it ran pretty darn well right out of the box. If your are willing to tinker and tune, then a Brawler or Proform 750 DP with changeable bleeds would be more flexible. The Holley 3310 750 with vacuum secondary gets a lot of recommendations for a mild 340 like yours too. If changing the carb, I'd put a Performer RPM or RPM Air Gap on it too. The original Torker intake wasn't that well regarded, and a dual plane will give you a better lower end torque on the street than that single plane.
Nice looking car.
rasmus westlin
Nice looking car.
Thanks for your tips! I would like to get this carb to work good, but i read about it and it seems like its known for having stumble issuses and hesitation when giving it light throttle. Some people wrote that you need to drill and change the whole metering block to get it fixed.
Thats why i lean more to try and change to another carb, this carb is atleast 10-12 years old. I know that all carbs needs tuning. But if i have to drill in the metering block to get the hesitstion and stumble to go away, then i rather buy something else.
Is all edelbrock torker 340 manifolds single plane? My friend told me that i have a dual plane? I have also thinked about to change it to a performer RPM. The car has no torque at low rpm, it starts to come alive only on higher RPMs. I wish it ran as good as it looks 😅
Just remember that the farther away from stock that you go with engine mods, the more tinkering you will have to do.
You always need to research the entire engine combo that you have chosen to be sure you will get the results you are looking for. Carb intake, cam, distributor timing, heads, compression etc... all need to work together.
Tuning is the term used to get everything working together. Like tuning a guitar. You need the proper strings in the correct places and the right tension or it will always sound bad. The wrong engine combo is the same.
Change parts and you have less references to tune it properly.
Once you start changing a lot of parts trying to fix it, you generally make it worse and very costly.
Try to get back to the original specs to get a baseline and go from there.
Never make more than one change at a time or if there is a change you wouldn't know which part made a difference.
The engine is a complete, matched package from the factory and millions of dollars in engineering and testing have gone into the factory package.
Street/strip doesn't always give the results you want.
The drag engine doesn't use vacuum advance because the pedal is on the floor. You want the advance to come in very quickly and the carbs demand to match the timing curve of the distributor.
When driving on the street you are almost always driving at part throttle, not to the floor.
Used carbs unless you bought it new are a crap shoot.
If you want used, go to a carb rebuilding specialist for that type of carb who can do everything including flow testing it.
Lots of used carb can have warped base plates from improper installation, worn throttle shafts etc.
The top rebuilders and address all these problems. In the end try to go new.
Dual plane manifolds always for street use. You are looking for low end torque.
Air Gap, RPM, Performer etc..
For street applications that have stock engines an Edelbrock Performer/Performer EPS intake manifold would be a great choice. Edelbrock Performer intakes also work well with applications that are running a mild camshaft. For modified engines running larger camshafts, it would be best to match up the intake manifold with the operating range of the camshaft your running or refer to cam card. Speak to the cam manufacturer if you need to find out the operating range of the cam. Edelbrock offers intake manifolds with matching camshafts to help eliminate the guess work.
540HemiCuda
West City Il
With a 4 speed and 3.55s, you don't need vacuum secondaries. Remember that originally most of Mopar's performance engines got mechanical secondary carbs whether they had an auto or a stick. If you do have a carb with vacuum secondaries you will likely need to change the spring for a quicker opening.
The best advise so far is for trying a different, known good carb. And the bigger the cam, the more 'tuning' the carb and ignition will need to accommodate it.
Intakes are designed to work in a specific RPM range. A dual plane is typically a higher torque, lower RPM range geared intake for use with milder and closer to stock engines. If however, you RPM range is higher than stock, then the open plenum would be preferred. To use a dual plane on a hotter engine would usually be a mismatch of parts. You need to match all components so that they compliment each other to the extent possible.
Again, your stick and 3.55s will be a lot more tolerant of a hotter engine combination that most autos and higher gearing.
pschlosser
Umm, yea. I support this forum where everyone's opinion can be heard. We all deserve that. But not everything people post, and not everything ChatGPT (AI) says is true, is based on reality or factual data. In some circles, AI = almost informed.
A review of the Chrysler Dealer Parts books for 1968-1971 years will show the only cars coming with mechanical secondaries (the AFB carburetor) was the 426 Hemi, and for good reason. That was the most performant engine in their product line, and still carries a prestigious reputation. This applies to both standard and auto transmissions.
With all this posted, I acknowledge when "making a car streetable" we give back, or compromise some of the power we might see from an ideal (for the track) setup. Unlike the track, we don't want all our power at the top end of the RPM scale. For the street, making the car more practical to drive on said street, we want some of that upper-end RPM in the mid and lower ranges, too.
This may be a pain in the butt if you don't have access to a working carb for testing, but if you did, most of us may agree it could be a big time saver to confirm if the problem(s) lies solely in the carburetor. If you don't have access to a working carburetor, don't worry about it too much. It just may take a little more time and effort to diagnose and solve the issue(s).
