transam
- Joined
- Apr 19, 2018
- Messages
- 47
- Reaction score
- 15
I noticed my taillights were not working and my side marker lights and also my dash cluster lights. I went under the dash and found a 20amp fuse blown. I changed the fuse, turned the light switch on and no side markers, no tailights and no dash cluster lights. I went back under and the fuse was blown again?? Any ideas on where I should begin to look. I have headlights and directional lights and the four way flashers work. I opened the drivers side panel and disconnected the rear harness, I installed a new 20a fuse, reached up and flipped the headlight switch and watched the new 20a fuse just melt in half??So do I assume that the rear end lights are all OK and where do I go from here. I really do not want to try and take the headlight switch as it is a pain to get the switch panel out of the dash? I did install a brand new front lighting harness and all new bulbs up front?? What about the brake light switch being shorted, as I also have no brake lights???
