73 barracuda rally dash wiring question.
There are stamped nuts that go on the engine compartment side that secure the fuse box/bulkhead connector.
I have another question I asked on another post about this. The wires that come down the steering column that connect to the main wiring harness. I was told they go up-and-over the steering column and were held in place by friction tape originally and to use zip ties.
My question is, do they go over the top to the left towards. The emergency brake .. Or do they go over the top of the staring column to the right in front of the fuse box? Thanks again
Originally the steering column wiring just connected to the dash harness just to the right of the column, never saw them wrapped up over the top of the column from the factory.
Thank you once again.That's what I was looking for I guess if you route them on the other side of the stairing column.Which there is enough wire that?It would get out of the way of the fuse block..
I don't know if you have looked at the other post or not but I was having issue with the after market turn signal, switch, that was already in the column.When I bought the car, it does not fit the original wiring harness.\nProbably will have to find one that fits and swap the plug out.If I cannot buy them separate
Where can I get the info that you are providing?Like the pictures and things... Is it in a book or literature that you've collected... I'm sure during the process of me putting this Cuda back together. I'm going to have a lot of questions I'm working on the routing for the defrost and heater control cables at this moment, I believe they run up over the steering column brace, but I'm not sure LOL
Factory service manuals, have a collection of them from around that time. Fairly easy to get originals, reprints or digital versions from various sources including Ebay.
Mymopar.com has some free downloads, but they don't cover all brands/years.
Thanks again, I will have to check into that.Do you happen to know the routing from theater?And default's control cables over to the heater box thanks
