Help needed, steering shaft nut size and thread
Hawaii
Does anyone know the nut size of the steering shaft? The one to connect the crush can to the steering shaft?
I have the car being shipped and am really in a bind as the shipper rejected the car because the steering wheel was loose. I’m flying up there to try and fix it but if you know the thread as I’m searching but coming up with nothing. I can find GM but the seller was a real piece of work and his mechanic didn’t secure the nut. It looks damaged so I don’t know if they even installed it.
Any help would be appreciated
Thank you
b3
In my minds eye it came into focus, being 1/2" 20. Take a lug nut off and try it. Lug nut is 1/2" 20. Then you know what is not. Or 9/16-18
thanks for the info. I searched all night on the red eye over and I couldn’t find anything distinctive enough but I search 1971 Challenger and 1/2-20 pops up right away smh… they don’t have any shallow nuts at Home Depot at the moment so checking Oreilly right now. Brought my tap and die for 1/2-20 so one way or another, it will fit
Found this in Steering shaft thread size in Cuda & Challenger General Discussion (ROSEVILLE MOPARTS)
Yeah I've now taken apart some more 1970 columns since that post on ebodies.org, some had the smaller 1/2" x 20 threads with the 3/4" nut, and some had the 9/16" with 7/8" nut. I think the bigger size may have been out of earlier built cars and at some point they switched to the smaller size, I think then it stayed the same all the way through 1974.
Yes, must’ve been 71 as this one was 1/2-20. I cleaned up the thread with a die and secured it. The horn is inop so I will go back in later to fix that and replace the nut with either nylok or blue threadlok.
My 74 Challenger is a 9/16-20, as are/were my '67 B, '74 A, and '80 F bodies. Finding this size at any general hardware store isn't happening. However, I did finally find a 9/16-20 lug nut at O'Reilly. It is a bit thick, but that can be corrected. Since it doesn't have the locking feature, I put a dab of Loctite on it
You could try Ace hardware if you have one too. They usually stock a good selection of nuts and bolts.
For the OP, my '70 'Cuda and my son's '73 Dart Sport are both 1/2"-20. 3/4" socket fits both and is the standard wrench size for 1/2-20.
Re. Ace Hardware, I can't tell you how many times I've chased around town trying to find some specific fasteners - not specialty automotive stuff, just normal hardware - and finally found it at Ace. They typically have a much better selection than Home Depot or Lowe's stores. I usually go there first now.
