Walter Phillips
Looking to build a stroker minimum 500ci with about 550hp with a 440ci block. What combination of parts do I need?
What's wrong with Comp?440 Source 512 kit , stock length rods with short lighter pistons Good heads & Cam [not Comp]
Nothing wrong with Comp. Yes, you hear some horror stories once in a while. You hear those horror stories about everyone's product eventually if you build enough engines. We build a couple hundred engines every year. Most with Comp Cams camshafts with no issues.What's wrong with Comp?
Something Mopar specific?
TIMINATOR
I have to respectively disagree. A larger Rod ratio does have two important advantages. First, the piston will dwell at top dead center longer which will help promote burning of the fuel/air mixture equaling more horsepower. Second, having a longer rod will reduce piston tilt inside the cylinder block greatly reducing cylinder wear. The Mopar Engineers gave our engines longer rods for good reason.I agree with much of what has been said, except for rod ratio. That used to be a thing that was a common concern, but data has shown it doesn’t matter. See engine masters and ihra mountain motors. Choose your piston and crank, then get something to connect it.
