1973 Challenger Rear End
What case and rearend would a 1973 Challenger with a 318 come with. 489?
The 1973 Challenger was only available with the 8-3/4" rear axle. The only 8-3/4" axle center section in 1973 was the 2881489 housing, aka "489", with a 1-7/8" pinion.
The standard gear ratio for the 1973 Challenger was as follows:
  • 318 or 340 with 3-speed manual transmission: 3.23:1
  • 340 with 4-speed manual transmission: 3.23:1
  • 318 with automatic transmission: 2.76:1
  • 340 with automatic transmission: 3.23:1
The optional gear ratio and/or Sure Grip for the 1973 Challenger was as follows:
  • 318 with 3-speed manual transmission: 3.23:1 Sure Grip
  • 340 with 3-speed manual transmission: 3.23:1 or 3.55:1 Sure Grip
  • 340 with 4-speed manual transmission: 3.23:1 Sure Grip or 3.55:1 Sure Grip (with A36 package)
  • 318 with automatic transmission: 3.23:1
  • 340 with automatic transmission: 3.23:1 Sure Grip or 3.55:1 Sure Grip (with A36 package)
The A36 Performance Axle Package included the 3.55:1 ratio gear set with Sure Grip, plus a 26" Mx Cooling radiator with shroud and power steering oil cooler (if equipped with power steering).
Remember that when it comes to original parts on Mopars, the books are not always 100% accurate.
My last 73 Challenger was one owner, original running car .
My 318, 73 Challenger came with a 741 pig.
If you can find a good 742, it is plenty strong an easier to set up than a .489. Much less expensive too.
