Cuda360-4
Good point. Thanks.Sounds like you may also need to re-center your axle within the body.
Factory service manual will tell you how. It is quite involved off the front suspension. Best done on a alignment rack. I just adjust mine to where I like it and even it up side to side bu measuring the center of the wheel at the lip. It doesn't need to be rocket science.After giving it some thought and look at various other e bodies, I think part of my issue is I think someone cranked down the torsion bars sometime in the past. What is the easiest way to verify stock right height in front? Measure from the center of the hub to the wheel opening? If so, what would that measurement be?
Thanks,
Kansan
