1970 challenger blower motor wiring diagram non a/c
Baron1958
santa claus in
I am building a 1970 challenger and need picture of wired blower motor or a wiring diagram none of the engine bay wiring was there when I got the car
The heater blower motor wiring in a non-air conditioned 1970 Challenger consists of two wires:
  • The green power wire connects to the resistor block on the heater box housing with an insulated spade terminal.
  • The brown ground wire connects with a ring terminal screwed to the mounting plate.
The following image shows the connections from the motor to the resistor box and mounting plate:
The following image shows the diagram of the resistor block to the dash mounted heater blower switch:
The C1A-14BK* wire leads to the fuse block.
If you don't have one, a copy of the factory service manual can be downloaded from the following link:
1970 Dodge Challenger & Dart Service Manual (363Mb .zip file of a compressed PDF)
