Has anyone modified the reverse light lenses on a 72-74?
Copilot....read post #8 for a quick explanation how I did this. As far as jus painting them red. My first attempt, I took reverse lens and removed the clear insert. fabbed up a center section of red lens to fit the hole and sealed it. It looked ok, but when illuminated, it only lit the center because the reflector ring was still there!
Since we’re getting sideways
Here is my solution
Grafted in a 2024 tail light
You have any pics of the inside of the trunk?
Any details on what you did?
The newer cars are HUGE, I'm guessing you had to cut and splice the new panel several places to fit?
This car is still a work in progress so the lights are not all adjusted yet for final assembly. There was no cutting the actual width of the 2024 tail lights. They come in 3 separate sections and when put together the width is near perfect fit on 70 - 74 challenger.
The headlights were a little more work
The newer Challengers are actually narrower than the old ones. Taller too.
