340 Motor Mount Change
moparnut74
Hello. Any suggestions / recommendations on how to change the front motor mounts on my 74 Barracuda with a 340. I'm a newby to this task. Thanks !
remove the cross bolt put a jack under the engine oil pan with a board to spread the load & gently lift the engine , remove the 3 bolts from the block mount & replace the isolator , I would use a better quailty mount such as Mag mounts that interlock & cannot separate . CHeck Rosevile Moparts or Mancini for better mount options
