1970 dodge challenger power steering box ?
wss340challenger
camarillo, cal.
hello ,my WSS challenger has power steering and im looking for info on a replacing the box with a swap from something else -- maybe a police car ?
dongei
SW Florida
I replaced mine from Advance Auto parts cost $49.00 and was an exact match to my original.
js29
lee center ny 13363
Firm feel rebuilds your core, and can put in A 16 to 1 ratio kit. there is A Pittman arm and idler arm kit to change the steering ratio as well.
SASSY
Strongly recommend "FRIM FEEL" They come in different levels of resistance and made a tremendous difference in my 72' challenger. They are resized/rebuilt and a perfect addition to the car. www.firmfeel.com
4404spd
I have the stage 3 firm feel. Its a little to firm but I'm getting use to it.
AUSTA
PERTH WA
Same FF3 with fast ratio pitman & idler arm tuff wheel major improvement over the stock the other option is the Borgeson Delphi adapted for the e body basically a landcruiser box appears to have the mounting plate welded to the Delphi housing.
with the adapter hoses & Shaft coupler pushing close to $900
rt63
New Jersey
Do you regret not going with the firm feel 2.My stock box needs to be replaced,the car is wondering all over the road.And I am still trying to choose between the 2 and 3.
Litchkar
Whittier, Ca
I put in a firm feel stage 3 box. It is tight like a modern car. No regrets at all.
Mopar Mitch
NW Chicago Suburbs
Litchkar -- Which ps pump are you running.. the Saginaw or the Federal? You probably know that the Federal pump cannot keep up with fastquick l-r-l-r- slalom type maneuvering, especially with any increased rpms. So... I, too, will probably be sending my current T/A ps box to FF for a rebuild, but... I'm wondering about Stg 2 or 3. I know some ppl that have stg 2 and said they should've done stg 3... and some that have stg 3 and are very satisfied... BUT.. I've never been able to test drive someone's car with either stg 2 or 3.. ABND that they have the Saginaw ps pump (the mFederal-ps pumps should all be thrown into the garbage, IMO, becaue they can't perform as described with fast l-r-l-r maneuvers (such as through slaloms, which my primary action with the car (T/A). Hopefully you have the Saginaw ps pump... so... could you try it out and let me (us) know???? would be most appreciated. I'll eventually talk/discuss with FF.
Also, I do like the Borgenson ps box, but.. since I have a T/A ps box already I may as well keep it (even though the lighter weight is appealing to me with the Borgenson ps box).
Pacoloco
Dongei, do you have the part# for that replacement from AAP, Im closer to the $50 range vs $900. I was qouted $70 bucks to rebuild my original but have heard so many bad things, figured I'd replace.
Any thoughts, thanks in advance.
74, Barracuda 318
dongei
SW Florida
The parts to repair it cost $8.00 but the replacement pump assembly is $49.00 from Advance auto Parts. You can check it out before you buy it , like i said before Mine was an perfect match.
71solo2challenger
Wallingford, CT
Mitch,
I have the FF Stage 3 with fast ratio pitman/idler & Saginaw box. Works great!! I wouldn't go down to the stage 2.
fm3426HEMI
chicago,il
firm feel satge 3 all the way with sector ceneter suppoert and idler roller bearing, hotchkis tvs, subframes and torsion bars and fox adjustables. car rides like a slot car..
