Catalog I found this article very easy to understand/follow basically you've got to get rid of that spade terminal that carries all the power through the firewall plug it is too puny and will get hot melting the plug, wiring insulation and possibly burn your car to the ground. I am going to enlarge the hole in my plug and run a thicker then standard wire through the plug with no terminals yes if I ever need to disconnect the plug I will have to pull the wire back through but that probably won't happen too often (I hope). Then I will disconnect and bypass the amp meter (who needs it anyway).
