Tilt Steering Column
Fordication
Houston, Tx
Does anyone have a post Chalenger tilt steering column they installed in thier car and how did it come out. I mean like one from another mopar.
There is no bolt in mopar OEM unit that can do this. By the time Mopar started using tilt columns, they had converted the wiring connectors and layout that would require customization to match the E body dash harness. But it can be done.
Easiest route for this is purchasing a pre-built unit from Ididit or some other vendor that will be a straight bolt in.
I purchased a universal tilt from ididit because I didn't want the key in the ignition as I'm going push button start. I removed the threaded plates from the factory column and will weld them to the tilt column so I can use the factory mounting bracket.
