Why does my engine only start after I release the key??
transam
I have been having issues with my motor actually only starting when I release the key?? Car ran fine for many years, As a precaution I installed a new ballast resistor, a new coil, and a new orange box. I did replace the ignition key several months ago and it was starting fine after replacing it, so this seems to be something new?? I have not done anything with the starter relay?? I am running out of things to check. I did check the connections at th bulkhead connector and also at the ignition switch harness under the steering column. They appeared to be fine. Any ideas. The car turns over fine but will not fire until I release the key??
Sounds like the run and start wires are switch somewhere. Check the steering column plug and the bulkhead connector. Make sure there in the right location.
22 Brown 23 Blue Remove connector under hood. Connect test light and check if it's working correct. You should only have power to the brown when in the key is in the start position.
Single or dual resistor? 4 or 5 pin?
Could be new ignition switch has failed in the start position with voltage not going to the coil and bypassing the ballast resistor. You may need 2 people to check this out. 1 turning the key to the start position and you checking voltage at coil.
Agreed, that's where I'd start.
Measure voltage to coil/ballast resistor while trying the key.
Disconnect connector on column and you can do it yourself.
Ignore stuff at bottom, that's for a 3G swap.
Dual ballast resistor? That's usually the issue.
Are you saying you have seen this issue specifically caused by a failed "dual" ballast? But not a single ballast.
Yes, the dual ballast resistors have a start and run side. The run side goes out and the only way to keep the engine lit is with the key in the start position.
I woke up today and it was a new day. After a lot of thinking I decided to look at my ECU orange box again. The system was purchased 15 years ago as a Mopar electronic ignition conversion. It came with a new Mopar distributor, orange box and the wiring harness. It has ran or many years nwith no problem just and just taken to shows in the summer 4 months. I changed the ignition lock because I missplaced the key and it appeared to be my only option. So I figured what the hell, just install a new ignition key switch. At any rate A also replaced the original orange box with a new one I got from Mancini Racing. So, I thought just for kicks and giggles I would remove that new one and replace it with the old one I had removed as I was thinking there was not really anything wrong with it. Before I installed the old one, It appeared to still have orange paint around the two hole where the screws mount it to the offset cooling bracket that I also put on the car years ago. So I sanded those two area clean, installed the old orange box. Went in and turned the key and the car fired on the first turn of the engine. I can't believe it was just that connection and now I think I understand that the newer 4 prong box and harness uses the box housing and screws to make a ground rather than that 5th plug. So, Check those graounds folks. Easy to overlook.
Glad it was an easy fix. Tracking down wiring problems can be a major nightmare.
I hate tracking down electrical gremlins, I feel like I need to bring in an exorcist!:mob:
Not my strong area of expertise but I finally got it. I was about ready to start pulling my steering column apart to look at the key cylinder that was brand new, but my better sense told me the odds are not there for this issue. These are the simple things that are so easy to overlook and yes, they drive me crazy as well. Now I am going to have to swap out my old orange box for the Mancini one and see if that works as well.
The bad grounds are phantoms that come back and haunt you. Their there but not seen in the minds eye.
I was going off of what you done last. Go back and check. confirm things are correct.
As you are about to do, it will give you a peace of mind of your issue. I would say you got it. Check the other orange box and you know.
The grounds are an important part. The chassis ground in front of the battery and the engine ground. There are others that are not given the attention and then they cause a problem. The diagram below shows what they are. If one goes bad then there can be some very erratic conditions arise. Electricity takes the path of lest resistance. ( That goes for the ground too.) That's how it happens. I put a ground strap from the cowl to the engine. I also put nutserts in place of the mounting holes. To keep it simple aways think what did I do last. 🤔 KISS
The ground strap going to the engine block to the bolt holding the voltage regulator and ECU bracket that @Challenger RTA posted above is a must for all our old Mopars!
Anyone looking at this post and doesn't have a similar ground to the engine and ECU, go but one and install it! Even if you have no issues without one now, you're better off with installing one!
