Jan 5, 2014 #1 M michael Well-Known Member Joined Dec 11, 2011 Messages 151 Reaction score 26 Turn signal lever is broken. It flops around I have to hold it manually to operate. What parts should I buy before tearing it down?
Jan 5, 2014 #2 74 challenger Well-Known Member Joined Sep 18, 2011 Messages 1,106 Reaction score 61 Location s carolina I believe your turn single cam is broke. Rockauto sells them. Not computer savy so I cant put up the link. http://www.rockauto.com/catalog/raframecatalog.php?ck[ID]=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=1loe8odb1qnsjclupfr2jgn5f2
Jan 6, 2014 #3 DetMatt1 Well-Known Member Joined May 13, 2009 Messages 8,339 Reaction score 2,414 Location Metro Detroit Your parts will likely be made by Shee-Mar and can be found on Ebay at good prices. Google Shee Mar and you'll find it.
Jan 7, 2014 #4 C Chryco Psycho Well-Known Member Joined Dec 28, 2008 Messages 5,222 Reaction score 2,915 Location Panama Standard part # Tw7 is the turn signal switch , the screw that holds the arm is probably loose , 2 min fix once the crush can is off
Jan 8, 2014 #5 moparleo Well-Known Member Joined Oct 17, 2011 Messages 7,343 Reaction score 2,150 Location So. Cal. Riverside area Moreno Valley Make sure you have some type of puller for the can and steering wheel. Of course dis-connect the battery before you do anything. Common sense.
Jan 9, 2014 #6 jaws Member Joined Jan 25, 2009 Messages 8 Reaction score 0 Location strasburg CO. X2 on the arm screw. mine cam loose in my roadrunner.
