1971 Convertible Seat Belt ID help
Shaker71
Kirkland, WA
I’m going through my parts to identify original 1971 challenger Convertible seat belts, so can get them off to restoration. Can someone with a 1971 convertible please let me know the tag numbers on your belts? I have a set that I believe is original to me car, but have boxes of belts and don’t want to restore the wrong ones.
or, show us the tag numbers, and we can correlate them with the (publicly available PDF of the) dealer parts book. Or you can do this, yourself. I suspect AI won't be able to help with this, until it matures further.
Thank you for the reply.
I used MMC Detroit books and they are of little help (vague for 1971 and convertible). I looked at the parts manual and it has tag info, but that doesn’t seem to match a couple of the belts that I know are original to the car.
Here’s a photo of the tag on the two rear seat non-buckle belts. I believe these to be original to the car I’ve owned since 1979.
I marked all the 1971 belts with model type 27 and there aren’t enough entries in the parts catalog for a complete set.
These are from my ‘71 convertible. The fronts have tags but the tags are missing on the outboard rears and if the inboard belts have them they are below the surface.
Thanks you for all the great input. I’ll do some more digging today and make a list of the belts I have. Is there a good resource for belt lengths and tag information for the convertibles?
I’ll see if I can find these in the parts book.
I'm not sure I've ever seen a chart. regardless of precise length or configuration, many of these belts will function in other cars. for example, the 3508 304 71+ C body front lap will function just fine, even if it has the extra shoulder buckle, in the E-body convertable. Not precisly correct, it is true. But you make do with what you have, until you find what you want.
it can take years to find a complete accurate set for your application.
I’d be happy to measure my rears. I should be able to do that accurately without removing the seat.
So the long inboard ones have a partial tag I was able to read and the last 3 of the part number is 281 and the belt material itself measures about 35”.
The outer ones just the belt material measure about 15”.
Modern American buckles look the same. I read that Pontonier was mostly Hamtramck and Pontonier was LA. But, my restoration shop said lots of the Hamtramck cars they do are American Modern? So, not sure.
I'm not sure I've ever bothered to understand the OEM maker's name of the seatbelts. I focussed mainly on the style, standard or deluxe buckles.
I like the retro feel of the standard buckles. But it looks like your car has the deluxe ones going for it.
Ok, here’s what I have with the help of the people that posted and cross referencing agaist the part manual. For 1971 E-body code 27-convertible the front seat belts part number end in 270 or 271 and the four digit code on the tag is 9008 or 9009. We have confirmed that 271 and 9009 are actually known through the photo provided by DeMatt1.
Then the rear belts are labelled last three of part number 281 and four digit code 9014. Thank you DeMatt1 for that part number and measured belt length.
The buckles appear to be Pontonier 600-1
