Hello Guys....
I need to remove my oilpan...because the gasket leaks a bit...and the Germany TUEV don´t like oil dripping to the ground....
My engine is a 340... and I am not sure, if the pan can be removed without Problems..because the motormounts are very very close to the panrail..
Also the 90 deg Adapter from the Oilfilter is leaking... to renew the gasket, I only have to remove the screw that goes through the Adapter... and the part will come off... right ?
Thank you for some advise
Greetings Juergen
Greetings Juergen
