WTB 440-6/727 kickdown linkage
Righty Tighty
Sahuarita, AZ
I'm running a 74 Barracuda that was originally a 318 car. Previous owner dropped a 440-6 into it, and I suspect he set up the kickdown linkage incorrectly. Currently, I have a one piece kickdown setup, and I believe I need the 3 piece setup. The one piece rod seems to be too short, and I'm having trouble dialing the shifting. If anyone has the 3 piece setup (or a one piece rod that's longer, if that exists) I would be interested in buying it. I have found reproduction 3 piece setups, but $300+ is a bit out of my range at the moment.
I tried figuring out a cable configuration, but the Lokar cable is designed to be pulled to operate, as opposed to being pushed like the rod. The way the Holley 6 barrel throttle lever is, I can't figure out a way to attach the cable in order to have it pulled for operation -- like the 4- and 2-bbl carbs.
