rklein71
My current project, 71 BG. I put in a 408 and a four speed. I had a 440+6 in my 69 383-s for nearly 25 years. I sold the engine to rebuild the original 383 and sold the car to fund my 71 project.
I guess I could just run a hot straight from the battery to the “run” side of the ballast resistor that would take the ignition key and under dash wiring out of the loop and see how long it runs then. Of course I better remember to take it off when I shut the car off. Thanks for you replyHave you checked the wiring in the loom from the firewall plug. Any replacement wiring may not be terminated correctly that would give you a weak spark.
Try another coil also.
You could run the ignition straight off the battery with jumper cables for a test.
Thanks for the thread do good info in thereRemembered reading this post a while back on the fuel issue.
Maybe some hints and tricks to assist you with your 6 Pack.
6 pack tuning
Doc,
Initially, I was going to comment that there should be 12.5 to 13.5VDC at the coil. However, being made to look foolish on too many assumptions in the past, I decided to check first. Measured my RUNNING 340 at the coil the other day with my good multimeter. Ignition on, not running, 13.2VDC. Running, 8.8VDC.
Think the meter is reading an average voltage. The voltage is pulsing??? Also thought the resistor was only used during startup to limit the current flow thru the ignition system due to huge pull for the starter. Back in the old days, the resistor limited the current to save the points during startup.
