aussiemark
There are nearly the same amount of parts needed to be changed for the 318 to 340 as the RB swap (if done properly) in most cases lets say you have a small radiator and you want the 727 rather then the 904 plus you still have to change one of the mount adapters and 340's have better suspension unless this was optioned in the 318 car. The exhaust will need to be changed to dual with different manifolds to suit the big port 340 heads. and if your car has a 7 1/4 rear axle you will need an 8 3/4. So you will need a transmission, driveshaft, radiator, torsion bars, rear springs, 1 x engine mount adaptor, exhaust system, rear axle and the accelerator cable brackets and kick down linkage so in reality the only other things you would need to change to fit an RB or B engine would be an engine wiring harness and 1 x extra engine mount adaptor. My car has a 26" radiator as part of the air conditioning package, a 3.23 sure grip 8 3/4 axle, S13 suspension and I will strengthen the 904 to handle the extra torque. My car will not need as many changes but not many 318 cars have these options fitted so going RB is not that much harder. Put the 440 in and have some fun with it rather the sell it at a loss and build another engine.A 318 to 340 swap is no comparison to a small block to big block swap. That would be just unbolt one and bolt in the other. Going to a big block changes a whole lot more.
