'70-'74 Challenger Door Differences
sdcbowler
Hello FEBO Members,
Wanted to ask. Is there a difference between the location of the window crank mechanism in the Challengers. Seems like I have seen some doors where the shaft of the window crank comes through the lower square cutout, and I have seen some where it comes throug the upper squar cutout? Which is correct for which years?
square cut out is for the power window switch
the regulator is in the same place
sdcbowler
OK,
I'm not referring to the square cutout in the 'door panel'. I know that is for the power window switch, and for the regulator the door panel would have an approximate one inch diameter hole in the same location. I'm referring to actual cutouts in the metal in the interior surface of the door itself.
sdcbowler
Chryco/EW
Thanks much for enlightening me........now I finally get it....:)
