727 Convertion
73fish
INDY
I'm converting from a 904 to a 727 (SB 340) 73 Cuda console slap stick will any of the linkage from the 904 work on the 727? I noticed the 904 has a shifter rod bracket mount molded on the tail shaft (2holes) & the 727 doesn't??
Phil
73fish
INDY
Is your 727 the sb model ? Pictures ?
I dont have have any pictures as the trans is at my builders, I did cross reference the trans ID when I got it it's a non E body SB trans any idea if any of the 904 can be used?
I haven't converted a 904 to 727 in a long time. IIRC only one piece of linkage is different. It is longer for the 727. I have a 904 73 Challenger and a 73 727 Charger at the shop. Both have 318's. I'll see if I can get pics later.
73fish
INDY
Pics would be very helpful I think I may have to get a different tail shaft or weld the shifter bracket in place? Anyone have any 727 SB linkage or pics of an E body set up?
I tried to get pics. Since the cars are on the ground I couldn't really get much. The 904 and the 727 linkage all looked identical. The tailshaft does need to have the two holed mount cast into it. You may have a truck transmission.
73fish
INDY
I do indeed have a truck trans does anyone know if I can just swap out the tail shaft case or will I have to swap out the input shaft as well?
thx
moper
Columbia, CT
You can swap the truck tail housing with a passenger car tail housing. You'll need new gaskets for the housing and the cover that lets you access the retianing clip that holds it in place. I've done more than a few of these and I've never needed to replace linkage parts for the shifter. The kickdown is another matter if you're changing intakes or engine families, but the floor shifter was always able to be adjusted.
I agree , shift linkage si identical for the 904 or 727 , & yes you need to swap the tailhousing so it has the mount holes for the shift shaft support to work
73fish
INDY
Thanks...I found a shaft locally should be good to go, driveshaft & wiring to go
Yatzee
Sounds as if the tranny you are going to use is from a truck. That tab hanging down with two hole can be sliced off and smoothed. That tab was used for mounting a damper that use to bolt to the tailshaft.
