73 barracuda tries to run only in the start position.
Flathead31coupe
Indianapolis
So after a little bit of time, I finally got the new wine harness installed new ballast resistor new starter relay. And came the grand moment to start when I tried it , it lit off as i'm holding the key in the start position stopped when I let up.. I'm sure it's been discussed a lot of times.. The ballast resistor drops down the votage from one side to the other.And on the other spade clip, it stays the same voltage.The ballast resistor has four posts.. Thoughts are appreciated..
You're not getting 12 volts at the ballast resistor in the run position which drops it to about 6-8 volts. In the start position you should have more volts to the coil, 8-10 volts, when you are in the run position check voltage at the ballast, or you are not getting voltage from ignition switch. Also check volts at the coil in the run position. A voltmeter is a necessary tool to check this.
Brown is start run is blue.
I have 6.5v coming from slot 22 the brn wire from the firewall to the ballast. I have 12.65 at the battery.. And I have the same volts on the red wire.. Going to the ignition switch .. But only have 11.5 on the fuses.. When I touched the positive cable to the battery with the key on or the off i hear something clicking on the passenger side in the dash.. Not sure if it matters or not.But I added a rally dash and wiring harness.
Follow the dots. Understand how it's wired first. Blue charge circuit, yellow battery supply, red ACC circuit. Headlight sw is feed from splice one under dash.
One word explains the wiring and connections. Inadequate! Read Description and follow the dots. The wiring is not heavy enough and the connection were not designed to carry that much amperage 1:RED wire 16 Battery power yellow dot to splice one feeds fuse block, 2:charge wire 18 black wire blue dots to splice one through amp meter to red wire blue dot 16 to battery, 3:ACC feed from splice 1 Red wire Q3_12R yellow dot to steering column. Black wire 12BK red dot to ACC side of fuse box.ch load. The round back alt has an output of 37 to 45 amps max and the wiring is designed for that.
When everything is in good shape.
In short. 1:RED wire 16 Battery power yellow dot to splice one feeds fuse block. Check the battery terminal at the fuse bottom of the fuse block for voltage. If it's not same there as the battery, there's a bad connection at 16. Don't forget to check the motor and chassis ground by the battery. To be sure you have a good ground connect to the battery negative. If you have good voltage when testing at the fuse box batt terminal. It's the ground somewhere.
In short. 1:RED wire 16 Battery power yellow dot to splice one feeds fuse block. Check the battery terminal at the fuse bottom of the fuse block for voltage. If it's not there the a bad connection at 16. Don't forget to check the motor and chassis ground by the battery. To be sure you have a good ground connect to the battery negative. If you have good voltage when testing at the fuse box batt terminal. It's the ground
In short. 1:RED wire 16 Battery power yellow dot to splice one feeds fuse block. Check the battery terminal at the fuse bottom of the fuse block for voltage. If it's not same there as the battery, there the a bad connection at 16. Don't forget to check the motor and chassis ground by the battery. To be sure you have a good ground connect to the battery negative. If you have good voltage when testing at the fuse box batt terminal. It's the ground somewhere.
I have 12.65 at that battery terminal....but 11.5 at the fuses... I will check the grounds...
