Differences in Challenger Grills
JedIEG
PA
Just out of curiosity- what is the difference in the mounting and fitting of the different years of challenger grills? I assume the 72-74 are all about the same and interchangeable but what about the 70's and 71's. Can they be swapped with the other years? Personally the 72-74 grills make those years the least desirable E-body's for me but they are always the cheapest cars. So a swap up front might make all the difference.
Technically all the grilles will interchange if you use the complete front fascia from the 72-74. The problem is 70 & 71 fenders have headlight buckets welded into them. The headlight buckets are in the fiberglass fascia in the 72-74. If you want to put a 70 grille and headlight bezels set up in a 72-74 you will need to weld 70 & 71 headlight buckets into the 72-74 fenders. I believe someone is offering the buckets for the conversion. The 70 grille weighs the least of all the grilles.
im looking for a complete grill an fascia, buckets ect must be in really good condition let me know please
i am also interested in this swap for my 74.. do you know who sells the headlight buckets?
thanks
you can just swap new 70 fenders on also
Dave @ Roseville Chry in Mi should have headlight bucket kits too
