Do you have worn door hinges? Let me rebuild them for you
res1vw21
As some of you know I rebuild door hinges for people, recently I have had to change my methods a little due to parts supply but it is for the best because now they are stronger and better then ever before!
Pricing is as follows for any standard mopar: A,B,E,F please email for pricing on C and early A.
$70 a side (top and bottom) or $130 both sides (top and bottom) + $15 shipping for the return ride. $50 core charge will be added if bought outright.
What you get for your money:
  • Media blasted clean
  • Epoxy primer in your choice of gray or flat black or left bare
  • New pins in all hinges
  • New brass bushings on both top hinges
  • Star wheels removed, repaired and reinstalled
  • Springs repaired
  • Assembled and and sent back to you labeled for position
The reason they are not greased is so you can paint them to match your car then use a spray lube type grease for long life.
Paypal Preferred, Money order is accepted.
Thanks a bunch
-Ross-
Here is a set headed out to a customer with a '65-'70 B body!
And a set headed to a customer with a '79 Aspen R/T!
Another set of A body ones waiting to be shipped out! (they were just painted hence why the pins and bushings aren't in the uppers yet)
Hinges
Just about to get into working on my 72 Cuda. I know the passenger door hinges are shot. I bought one of those hinge repair kits, but this sounds better. Where do I send the hinges? Thx
