sheetmetaldan
Ok I have a few questions. Yesterday I was changing the dist cap and wires when I bumped the vacuum advance and the dist moved turns out the previous owner must not have tightened it down.The motor has always run a bit rough but with open manifolds I didn`t do anything to it.Now with an exhaust on I can take it for a spin up the road but like I said it`s rough.I`m sure the timing needs adjustment what is a good starting point for it? I have a new fuel tank,lines and filter and fresh gas.The only thing not new on the fuel side are the sending unit and carb.Also have new dist cap,plug wires as well. I forgot to grab a rotor but the one in there looked clean but I will replace it when I get another one. The plugs were dark but no crud/deposits on them I may replace them as well just to rule them out. Is a 035 gap about right for plugs?
When the engine warms up it will maintain a rough idle and when I try to drive it I have to keep playing with the gas pedal to keep it running lots of hesitation/stalling when giving it gas but it does start right back up easily.I am wondering if I am having accelerator pump or vacuum issues or maybe both.
Last thing I am leaking some oil out of the thing next to the distributor with one wire on it(oil sending unit?). Is there a special socket to remove it or do you just put a pair of pliers on it and go. It`s a little hard to reach and I don`t want to ruin it in my attempt to get it out. Thanks for any help!
