FALL FLING XXI WOODLEY PARK, VAN NUYS, CALIFORNIA OCTOBER 29, 2016
autoxcuda
Los Angeles
Leo, thanks for posting this.
The date in the thread title may confuse some folks. Could you edit It with the October 29 date?
C O D Y
Also, is there a group code for the hotel? Looking forward to making the event. Thanks for sharing the info. :)
autoxcuda
Los Angeles
Cpwclub or just tell them you are with the Chrysler show.
If there is a problem, call 9-5 M-F.
C O D Y
Just called and reserved a room. The group rate this year they said is $149
autoxcuda
Los Angeles
Leo, could you edit you first post and change the date in you title to the 29th ?
You just click the three black lines at the bottom of the post, then click edit.
autoxcuda
Los Angeles
Bringing these parts. Deals to be had at show without me hassling for shipping
-disk brake swap complete with the desirable 73-76 A-body/73-74 E-body spindles. Has pin calipers. Was off 73 Challenger $250
- Manual steering box. $75
drivers side E-Body w/sway bar bracket. So Cal no rust pits $100
Other new stuff. P/N's listed 30%-50% off new price
  • MSD RPM Activated Window Switch 8956
  • MSD 2 Step Module Selector 8739
  • Auto Meter 5330 Quick-Lite Shift-Lite, Black 5330
  • Auto Meter 5411 Pro-Comp Mechanical Fuel Pressure Gauge, 15 PSI, 2-5/8 5411
  • Auto Meter 5426 Brake Pressure Gauge, 2-5/7 5426
  • Auto Meter 5427 Pro-Comp Air-Core Oil Pressure Gauge, 100 PSI, 2-5/8 5427
  • Auto Meter 5154 Pro-Comp Mechanical Speedometer, 160 MPH, 5 Inch 5154
  • Auto Meter 3904 Tach 5" Monster 3904
  • Auto Meter 3332 Sport-Comp Water Temperature Gauge 2-1/16" Mechanical 3332
  • Auto Meter 5492 Pro-Comp Air-Core Voltmeter Gauge, 2-5/8 Inch 5492
  • Auto Meter 3375 Sport-Comp Digital Narrowband Air/Fuel Ratio Gauge 2 1/16 3375
  • Auto Meter 5416 Pro-Comp Air-Core Fuel Level Gauge, 2-5/8 5416
  • Auto Meter 5437 Pro-Comp Air-Core Water Temp Gauge, 2-5/8 Inch 5437
  • electric fuel pressure with hi lo memory 5462 5462
  • Super Powershot Nitrous Oxide Systems -Spreadbore P/N 05104-20NOS
  • SCE Copper header gaskets 4069
  • Mopar Perf R3 4 bolt main cap package P5249669
  • Mopar Perf 8 3/4 pinion snubber P3690182
  • Mopar Perf Green Bearing Set P5249444
  • Mopar Perf SB Tach Drive Distrib P4120701
  • Mopar Perf SB Bronze Gear oil pump drive P3690874
  • Mopar Perf High-pressure Valve Springs P4120785
  • MP Rear Mount Battery Kit P4349500
  • Mopar SB late water pump New 95' up
  • Cirkit Boss Circuit Isolator 70107
  • Stage 8 Locking Exhaust Kit 8915
  • Champion Racing Spark Plugs 687
  • Champion Racing Spark Plugs 688
  • Willwood Parking Brake Caliper Drivers Side 120-2281
  • Willwood Parking Brake Caliper Passenger Side 120-2280
  • Chrome-Plated Front Timing Chain Cover (1968-91 426 Hemi® and All Big Block) EG-TD9392
  • Stereo Noise Filter disc'd S-10-A CL
  • Moroso Cast Alum. Electric Water Pump -Modified for SB Mopar 63546
--Complete B-body 66-69 4 piston Bendix disk setup. $250
-NEW in box 383 air grabber base and lid repro PN 121-AG383 $260
-New K&N air cleaner E-1980 for air grabber $60
passenger side 67-69 B-Body w/sway bar bracket. So Cal no rust pits $100
autoxcuda
Los Angeles
Bringing these NOS and new mostly E-body parts. Discounted for show pick up.
  • NOS Challenger Flip top cover in box NOS $350
  • NOS R/T stick on emblems in package 3445223 NOS $39
  • NOS R/T stick on emblems 3445223 NOS $39
  • NOS E-body & 71-up B-body shifter boot 3467770 NOS $150
  • NOS E-body washer reservoir NOS $65
  • NOS Front End Seal Package - 1968-76 A- and E-Body P5249226 new $150
  • E-body & 71-up B-body shifter boot ring new $20
  • TTI 2 1/2 full exhaust system E25HWM-CH new $350
  • Legendary Black Wide Seam Vinyl Top KT152BLK new $120
  • Legendary Black headliner AH756100 new $25
  • 22" B/E Fan Shroud 2998328 New $125
  • Four Seasons 94508 Heater Core Non A/C 94508 new $40
  • E-body, 71-72 B-body Repro Battery Tray Brace new $10
  • 72-74 E-body, 72-B-Body Battery Hold Down clamp set New $15
  • ACC black E-body 4 speed carpet new $95
  • 1972-74 Challenger Quanta Gas Tank w/ECS (4 vent tubes on "front" of tank) GT-212075072 new $120
  • E-body 3/8 fuel pick up 845 new $29
  • new pistol grip lense new $10
  • PISTOL GRIP UPPER BEZEL PGUB new $20
  • PISTOL GRIP LOWER BEZEL PGLB new $20
  • custom carved pistol grip handles PG08 new $30
  • Energy Suspension Poly Strut rod bushing kit 5.7109G new $15
  • 4 Challenger wheel lip moldings new repro 158-WOM7074J new $125
  • front challenger bumper cushions repro 124-HA11 new $15
  • rear challenger bumper cushions repro 124-HA12 new $15
  • E-body under dash insulation 181-UDI7074E new $10
  • E-body Headliner Insulation 103-HLI103 new $10
  • Firewall Pad 1970-74 E-Body W/O A/C 181-FWP7074E new $20
  • Kick Panel Insulation 1970-74 E-Body 181-KPI6670B new $15
