I think my 3 yr old Precision fuel pump that's on my 1969 383 in my 73 Challenger is pumping out too much pressure/gas and in return, flooding my carb, along with some of my spark plugs. I had plugs last yr that fouled once, but this yr it has gotten worse. The worse plugs are generally on the passenger side, 4,6,8 and sometimes plug #7 on driver's side, probably cause of engine tilt. When I take these plugs out, they are either wet or have sticky glossy black stains on them. I'm running NGK XR4 plugs, gapped at .035 and I'm currently on the second set this yr. After cleaning the plugs or replacing them, it runs good for a trip or two.
The 2 main symptoms while on the road are:
1) slight hesitation, especially in 1st and 2nd gear
2) backfiring in the exhaust pipes while deacceleration in 3rd gear
I thought that it was the old Edlbrock 750 carb initially, so I took the air horn off and noticed some crud in the bowls along w 2 incorrect jets, along w the wrong metering rods which weren't even the same as ea other. Floats were set correctly. Unfortunately, after correcting these issues, it was having the same issues.
I decided just to upgrade to a new AVS2 650 #1906 carb. I also purchased a 1" Mr. Gasket plastic type spacer to help w vapor lock. (I mounted it w the cavities mounted on the intake manifold side) I also put a new fuel filter on.
Unfortunately, after the new carb along w a new set of plugs, it was doing the same thing after running well for the first few miles, but after turning the motor off for about 15 minutes, on the way home it started to act up again.
Yesterday was the worse day yet. After cleaning the plugs, on the road it was hesitating and backfiring again but this time, it stalled while going around a street corner and really struggled to restart. Once it did restart, it barely stayed running to get me home w some pinging also and while going up my steep driveway, the motor pinged worse yet. This was something new.
I suspect now that it is a bad fuel pump and plan on purchasing a Carter M4589 pump along w a new fuel filter. I have heard that Carter pumps are a lot better quality vs Precision.
I'm sure this has nothing to do w my fuel related symptoms but just to note, after replacing my old Chrysler distributor 3 months ago w a new Proform #440-431 distributor is when the issues seemed to of gotten worse.
Any suggestions appreciated!
