head lights
Cratos
Sunny Florida
Well I had the Grinch out at night for the first time ,and the darn head lights would just go out and then come back on a min later!! all wiring is new as is everything else switch was supposedly gone through when the dash was sent out and reconditioned. Also when I hit the brakes the light flicker once.
Any ideas? ( if it’s not one dam thing it’s another!!!
I would upgrade to relays for the headlights all modern cars use relays , no point in putting all of the current through the headlight switch & the bulkhead twice . WHich light flickers when you hit the brakes ?
Very much agree!
....and pack your bulkhead connectors with die-electic grease like Chryco recommends....
Cured all my gremlins but still hook up the headlight relays...!
If you get active action on unrelated circuits, that sounds like ground hunting.
installed your harness to day No low beams but both hi & low on hi and checking that there is No power into the low beam relay? checked fuse and swapped relays still No power coming into the low beam fuse.
Also check the floor low/high beam switch the centre should be positive mine wasn't making would lose lights after a few minutes
Sent you a PM. I bet I solved it in the PM...
Won't have anything to do with the OEM side of the system.
This! Had the same problem and replacing the floor low/high beam switch fixed it.
T
when any pre 78 car came in with the problem described all we would do is replace an aftermarket dimmer switch with a genuine 1881938 switch
