How many out there running 340 engines in there E Bodies???
djais1801
Sand Box
I am, it's got a mild cam, exhaust manifolds w/ a heat riser into the air cleaner... 340.jpg
moparlee
Mid Michigan
Me too in one of my two '71's. This is a matching numbers 340 auto car, unsilenced air cleaner. Currently under going a full restoration.
AUSTA
PERTH WA
Just curious how many out there are running 340 engines in there e bodies?
I have 3 1 in A66 , 1 in TA , Chrysler bought 200+ 340 engines into Australia for the E55 Valiant Charger the engine number is stamped on the shoulder above the starter motor the areas where Dodge normally stamped the no are left blank most castings were 69 mine is stamped E55 3.31 023 number 23 with 3.31 ,I think the stroke was shown as they were for Bathurst racing
03HDFB
340 Based 408 Stroker....Love It!! Almost done installing the Fast EZ EFI 2.0....Its the perfect drivers car now!
djais1801
Sand Box
that is a sick air cleaner cover!!! man that engine is clean...that would take me forever to keep shining!
03HDFB
Thanks.....Here's an updated pic...Just about have the Fuel Injection done, Completed are...Electric Fan, HUrst Roll control mounted
on the master, Master/Booster Swap...The rest in in my Thread.
wmann
My 71 Challenger engine bay looks close to identical to the one in moparlee's picture. moparlee is yours a GK6 challenger? That's what's I own and mine's a 340/4sp.
Bill
Vermont
Dragcaar
340 Stroked to 355 Ci X block makes over 600hp ALL of my Cuda are using 340's for power. (I am fortunate enough to have 3)
crash520
Ipswich, Australia
I have a factory original 340 in my Cuda for now building a 408 with W2 closed chamber heads and injection. Dracaar, do you have some engine build specs to share on those 600hp engines please? im looking at hitting similar numbers and am curious on what you have done, I know its pretty easy now days but just curious. Any pitfalls to say away from?
Dragcaar
340 W Kellog 355 Ci Crank Eagle Rods, Ross 13.5 Pistons '810' W2 Iron W2's with full port and polish (I have a Flowbench at home) Closed Chamber. (make sure you clay it and use GOOD pistons) Total seal ring Pak. Peak flow at .700 was 315cfm Int.2.05/1.60 long valves. Using a .620li roller. Oil control crossover. Smith Brothers Pushrods. Old School Mopar Rocker Gear (blue Rollers) Titanium Stands +.100 Mopar '408' intake Ported. Holley 850HP Canton Oiling System(this is critical) Fluid Damper. Rollmaster Chain. MSD Probillet. Studded mains and heads Cometic Gaskets. Made 605HP at 7300Rpm on the Dyno
