ignition timing
John h
Hi All,
I have a Crate Magnum 360. It's the 300 HP model. I am using Fitech throttle body and it's also controlling my timing. I thought it was running great and I had good cold starts and good throttle response. no pining or run on. The base timing is set at 12* and the handheld agrees with the timing light at Idol and at 1500 RPM. I have an adjustable phasing rotor. The timing curve is whatever their base tune was. I can get the numbers if it becomes an question later, but my current issue is with starting. When the engine would be run to operating temp around 190-200, sometimes I would get kickback when I tried to re-start it. it was not super often but something that would happen only when warm. over the winter here in Wisconsin, I changed out my headers to some Ceramic coated ones and put in a High torque mini starter. After the starter change I would get kickback and very ugly engine buck on every start even if it was a cold start. I read about timing being too advanced will cause this. I marked my #1 post on the cap with the dist body. I rolled the engine around to TDC on #1 (compression stroke confirmed) the mark on the ballancer was exactly at 0 timing mark. I rolled it backward to 12* before. I pulled the cap off and the rotor was pointing past #1 on the way to #8 so it was looking like it was retarded not advanced. I pulled the rotor and made sure the reluctor was centered on the magnet, it was. I put my rotor back on and re-phased rotor to lineup with the #1 post exactly. I never adjusted the dist timing at that point. I started the car cold and it fired right up and no kickback etc. when I warmed up I checked the timing and it matched the light with the handheld computer for Fitech. I checked the warm starts multiple times after and starts up and no kickback. why would it run nicely before if I was technically firing on time but the rotor was way past the post? is the starter rotating the engine so fast now with the high torque that it was trying to fire #8 rather than #1 with the new stater? would I have just had really weak spark when I was turning higher RPM if the rotor was already past the plug post moving to the next cylinder? Would my fuel learning tables have adjusted for less fuel since the spark would have been so weak? How could it have ran so nicely with such weak spark? Please hit me with your opinions. I can't drive the car for proper testing now it's -3 in Wisconsin and we have tons of road salt. It's driving me nuts thinking about this and not being able to test.
Thanks, John
I have two thoughts on this. Is the Fi-tech allowing too much gas at start-up, when warm? Is there a way to check/adjust that...
Have you checked total timing at 2500 rpm? I usually set mine at 34-35 degrees, btdc (without vac advance) and I don’t worry about initial timing..
John h
you can adjust prime fuel and crank fuel.
I did not check total timing but I think the tune that is in there is 38* total.
38 seems a tad high; I would back it down to 34 and see if it helps.
John h
I can back it down, but most of my questions revolve around the Base timing of 12* and why I would suddenly get kickback on every start with a new high torque starter and why the rotor was past the #1 post on the cap rather than before the #1 post. Since we have only 2 ways our distributors can go in, we can't be off a tooth or can we if the drive gear jumped inside the motor?
moparlee
Mid Michigan
My 2 cents for what it's worth. Check to make sure the dampner has not slipped. On the compression stroke, put a piston stop in the #1 plug hole, rotate the crank CW until the piston stops and put a mark on the dampner, rotate crank CCW until the pistons stops again and put another mark on the dampner. Half way between these to marks is your TDC.
I agree the rotor position was wrong causing the spark to jump to #8 or both terminals , by phasing the rotor properly you have eliminated the problem . my Theory is that the Mini starter turns the engine over faster so in the milliseconds it took for the spark to actually reach the rotor it may have been closer to #8 causing a more frequent kickback .
AS for the actual timing setting I never use a timing light but instead let the engine tell me what it likes best
John h
I will need to study up on these piston stops I have never used one. I don't have one. I will look into it. when I got the piston to what I assumed was TDC, the dampner mark was at 0 so I just assumed that was good. But I see how if the outter ring let go it could be wrong. That would be a reason for the rotor not pointing at #1. But now thinking about it, the Fitech handheld was telling me what timing it was giving it and the timing light agreed. even at 1500 RPM, the dial back light could zero it out. so if the handheld said 12* at idol, the timing marks and light agreed. at 1500, the handheld said 26* I think and the dial back light was able to show zero when I put the value into the timing light. If the timing chain slipped wouldnt that screw up the timing not just rotor position? Maybe my billet distributor is faulty... It's a TSP and under 3 years old with maybe about 1300 miles on it. Purchased new for the Fitech install.
Robert Franke
Mineola, TX
I think your overthinking it! I agree with Adam. Basicly. 34 to 35 total! If your backing it up 4, your taking the initial back 4! So that means your starting (base) timing is at 8...much better if your getting hot start problems. The total advance is built into your distributor. Springs adjust rate or speed of advance...More reading to keep you busy..This is basic mechanical distributor ops. Hook up your Light and if it has a dial put 34 in it and adjust to TDC at max RPM ..When it quits moving-advancing. That RPM will tell you the RPM total @ ...Have fun...spring is commin!
AUSTA
PERTH WA
Hi All,
Thanks, John
What distributor & ignition box are you running
I notice on my ready to run MSD it does the same thing if the battery is slightly low if it goes below 11.5 it wont spark at all for some reason when the battery is low it seems to go into advance when starting .
My mates Dodge ram 360 has the same problem with kick back (Not every time) he is running a Fitech with MSD ignition
gtx71
John,
You have you base timing set for 12 degrees, what is you idle timing set at. Base and idle are 2 different settings. Base is what timing the engine will start at, idle is what it will idle when engine is warm. 12 at base and total advance at 39 is a total timing swing of 27 degrees. i believe that at some point the rotor in relation the #1 terminal will be retarded. the distributor cap terminals (8 in total) are 45 degrees apart. the rotor to cap terminal are most likely never in perfect alignment.
Tony
John h
sorry for taking so long here. I did not mark the post to tell me when there was a reply.... I'm using Fitech for spark control I'm using a TSP billet distributor with a Phasable rotor. If I dial the rotor back I get less kickback now but have not tested it warm.
John h
John,
John h
My initial timing is set at 12* Idle timing is at 14 right now. The directions say set initial timing at whatever is best for your motor (in my case, crate instructions say 12*) and verify with timing marks and gun. Then turn your rotor to +12* and lock it down. I was very confused by this but drawing a picture out, I think I understand. When the car starts and the computer decides its at idol, it fires 14* before TDC it's firing before the #1 post so essentially, it's moved the rotor position counter clockwise from it's base position. spinning the phaseable rotor to an extra 14* to match idle timing, it would put the rotor as close to the post as possible. Now in my case 12* base timing the rotor was already past #1 cylinder, not lined up or before it. turning the rotor another 14* moved it way close to the #8 post and the spark was likely lighting the fire in both cylinders before the computer actually advanced the timing. I twisted the rotor to match the #1 post at base timing of 12* and it ran fine until I ran it up to about 2000 RPM. then it popped back in the throttle body. it should have been throwing around 26* timing at 2K RPM. I don't know if I went lean or fat or it was just not sparking close to the correct post. I pulled the cap and advanced the rotor slightly past #1 at base timing (12*) and it started ok, but did not idle as smooth. I'm planning on setting base timing at say 10* and Idol at say 12* and play with rotor position more. I will eventually drill a hole inthe cap at the #1 post and see where the rotor is at idol and up to max timing. I just hate to destroy a perfectly good $40 cap.
